Author Topic: Wheel liner info - are yours cracked?  (Read 21349 times)
« on: August 02, 2011, 01:35:18 PM »
Are any of your wheel liners cracked?
Post here your car model and which wheel liner.
For those in the tri-state area or frequently come to my mod meet, I may be able to get replacement liners at a great savings.  There one catch, I have to buy a shit load so I need to be able to justify doing this.
The first three numbers is the part index (see attached pics), followed by the GM part number
Solstice Rear
007  25975691  LINER. Rear Wheelhouse
LINER,RR W/H PNL - LH. Required: 01LHD. For: M67 (2006-2010) (2007 - 2007).  $38.45
007  25975692  LINER. Rear Wheelhouse
LINER,RR W/H PNL - RH. Required: 01RHD. For: M67 (2006-2010) (2007 - 2007).  $42.95
Solstice GXP Front
014  25914761  LINER. Front Fender Inner Wheel House
LINER,FRT W/H - RH. Required: 01RHD. For: M TURBO GT(GTA) (2007-2010) (2007 - 2010).  $74.80
014  25914762  LINER. Front Fender Inner Wheel House
LINER,FRT W/H - LH. Required: 01LHD. For: M TURBO GT(GTA) (2007-2010) (2007 - 2010).  $74.80
Solstice NA Front
014  25914763  LINER. Front Fender Inner Wheel House
LINER,FRT W/H(USE T/W 15840526 EXTENSION) - RH. Required: 01RHD. For: M (2006-2006) (2006 - 2006). RHD. For: M (EXC TURBO GT(GTA) (2007-2010) (2007 - ... Show More  $75.80
014  25914764  LINER. Front Fender Inner Wheel House
LINER,FRT W/H(USE T/W 15840527 EXTENSION) - LH. Required: 01LHD. For: M (2006-2006) (2006 - 2006). LHD. For: M (EXC TURBO GT(GTA) (2007-2010) (2007 - ... Show More  $68.60
Saturn Sky Rear
005  25797157  SHIELD. Rear Wheelhouse.
SHIELD,RR W/H PNL - LH. Required: 01LHD. For: M (2007-2010) (2007 - 2008).  $35.32
005  25797158  SHIELD. Rear Wheelhouse.
SHIELD,RR W/H PNL - RH. Required: 01RHD. For: M (2007-2010) (2007 - 2008).  $38.10
Saturn Sky Redline Front
020  25831930  LINER. Front Fender Inner Wheel House.
LINER,FRT W/H - RH. Required: 01RHD. For: M MERLOT JEWEL SPECIAL VAR 2 PKG(1FW),HYDRO BLUE SPECIAL VAR II PKG(1FZ) (2009-2009) (2009 - 2009). RHD. For... Show More  $52.13
020  25831931  LINER. Front Fender Inner Wheel House.
LINER,FRT W/H - LH. Required: 01LHD. For: M MERLOT JEWEL SPECIAL VAR 2 PKG(1FW),HYDRO BLUE SPECIAL VAR II PKG(1FZ) (2009-2009) (2009 - 2009). LHD. For... Show More  $53.12
Saturn Sky NA Front
020  25831932  LINER. Front Fender Inner Wheel House.
LINER,FRT W/H - LH. Required: 01LHD. For: M (EXC DAEWOO(DRX),TURBO GT(GTA) (2007-2007) (2007 - 2007). LHD. For: M (EXC DAEWOO(DRX),TURBO GT(GTA),MERLO... Show More  $55.97
020  25831933  LINER. Front Fender Inner Wheel House.
LINER,FRT W/H - RH. Required: 01RHD. For: M (EXC DAEWOO(DRX),TURBO GT(GTA) (2007-2007) (2007 - 2007). RHD. For: M (EXC DAEWOO(DRX),TURBO GT(GTA),MERLO... Show More  $55.97
Re: Wheel liner info - are yours cracked?
« Reply #1 on: August 02, 2011, 01:46:11 PM »
Depending on the price I may want a set for the front just to have as spares.
GXP RF 25914761
GXP LF 25914762
My dealer replaced one of these for me right before I went to England, they were kind enough to F'up my fenders in the process too, so I get to work with that now.
« Last Edit: August 02, 2011, 01:50:24 PM by DeepBlueGXP »
« Reply #2 on: August 02, 2011, 01:49:02 PM »
I may be able to get them for half the cost or less depending on how many I can get.
Please post your car and which ones.
LF - Left Front
RF - Right Front
LR - Left Rear
RR - Right Rear
« Last Edit: August 02, 2011, 03:37:35 PM by DeepBlueGXP »
Offline DRM
« Reply #3 on: August 02, 2011, 01:54:58 PM »
Do the front liners come with the weather strip that helps seal the liner with the hood?  My early 07 GXP did not come with this weather strip.  I had to order them individually...I just tried to order another yet...not available separate anymore according to my dealer.
    • Ryuk
« Reply #4 on: August 02, 2011, 02:15:29 PM »
Both of my fronts could use replacing.
To help with the quantity, I would take 2 full pairs, just to have a spare set.
« Reply #5 on: August 02, 2011, 02:30:54 PM »
no, those strips (clear 3m)were supposed to be applied to the inside of the hood, not on the wheel liner itself.
« Reply #6 on: August 02, 2011, 02:44:54 PM »
My fronts are cracked but only the passenger-side was replaced under warranty.  The driver side has additional cracks from impact by the previous owner.
I use modified door weatherstripping to seal the gap between the hood and the fender liner.  I managed to get a couple used weatherstripping from an E36 M3.  I've lost one before and replaced it.
« Reply #7 on: August 02, 2011, 02:51:02 PM »
Somehow, I don't think mine are cracked and I didn't notice any cracks when I was cleaning them the last 2 days.  I'll take a better look at them and let you know.
My fenders are both dented though.  One is pretty bad.   :mad:
You could make a small fortune if you could get your hands on fenders!   :D
Offline DRM
« Reply #8 on: August 02, 2011, 03:06:49 PM »
No not that...The long black weather/seal strip attached to the liner.
#19 in the link below: (also #13 in your second diagram in your first post.)
http://www.gmpartsdistributor.com/partlocator/index.cfm?action=getJointLocator&siteid=213761&chapter=&Sectionids=0,2399&groupid=51836&subgroupid=9450&componentid=0&make=28&model=Solstice&year=2008&graphicID=FG06075&callout=19&catalogid=3&displayCatalogid=0
« Last Edit: August 02, 2011, 03:15:14 PM by DRM »
« Reply #9 on: August 02, 2011, 03:20:17 PM »
just for the sake of info, when i was doing the turn light mod, i noticed that each one of the front have a small crack at the point where it connects to the bumper.
i suggest, that since Joe can have a good deal on them, anyone should buy at least a spare set.
just my 2 cents
« Reply #10 on: August 02, 2011, 03:36:35 PM »
A dead blow rubber mallat and a padded chair is all I need to do wonders to fix the dents on the fender.  I have straighted many this way so that they are barely noticable.
« Reply #11 on: August 02, 2011, 04:04:25 PM »
Right front, but I expect it will get plastic welded someday.
« Reply #12 on: August 02, 2011, 04:19:45 PM »
My front liners are cracked for the second time this year. At the fastening points of course. The push pins were put in the last time they were changed in May and now they are cracked where the screws fasten it to the bumper. Two sets in a few months is just ridiculous.
I am going to see if I can try and get the liners from the dealer before they replace them this time as this will be my last set as the warranty is expired. I hope that I can reinforce the back of them with JB weld or something. I don't want them cracking again.
That said, I may be interested in a set just in case I need them over the next 20 years or so.   :(
GXP
LF - Left Front
RF - Right Front
« Last Edit: August 02, 2011, 04:26:13 PM by Sly Bob »
« Reply #13 on: August 02, 2011, 04:24:23 PM »
I wonder why I don't have that weatherstripping on the edge of my wheelhouse liners. I noticed it on a few cars at the mod meet but I have never had that on my car. Anyone else?
« Reply #14 on: August 02, 2011, 04:26:15 PM »
home depot is your friend, or Lowe's
Offline DRM
« Reply #15 on: August 02, 2011, 04:57:47 PM »
They were a later addition.  There was a discussion on the SF about these a while back, so I ordered a set, cost about $9 to $14 a piece.
A month ago I decide to order a second set from a local dealer, part number was nolonger any good and it looked like it came as part of the front wheel liner now.
So I am just curious when folks get the front wheel liner that Joe is ordering, will the weather/seal strip come with it.
« Reply #16 on: August 02, 2011, 05:45:18 PM »
The liner that I had installed in the spring didn't have it.
This page shows the weatherstripping (#13) comes with the fenders but it also shows that the liners are not available. It would be good if the weatherstrip came with them but I wouldn't hold my breath.
http://www.gmpartsgiant.com/Page_Product/PartDetail.aspx?modelYear=2009&model=Solstice&make=Pontiac&catalogCode=2M9&modelCode=2MB67&seriesCode=2MB&bodyStyleCode=67&engineCode=LNF&transCode=M82&majorIndexID=08&isBigPicture=False&minorIndexID=2M0800202
« Last Edit: August 02, 2011, 05:55:15 PM by Sly Bob »
« Reply #17 on: August 02, 2011, 06:08:28 PM »
I'd take a set of front liners.  My Driver's side one is cracked where it bolts onto the fender, but I may as well replace both of them...
Offline JimVonBaden
« Reply #18 on: August 02, 2011, 06:34:16 PM »
Depending on price:
Jim :cool:
« Reply #19 on: August 02, 2011, 06:37:12 PM »
My front ones have just started cracking around the fasteners. Not enough to warrant replacing yet, but if the price is right I'm in for a pair of RL front liners.
2012 Chevy Camaro 2SS RS LS3 TR6060
2018 Dodge Charger Daytona 392 HEMI
1998 Ford Mustang - Getting a transplant as soon as something major breaks
« Reply #20 on: August 02, 2011, 06:42:05 PM »
Here is what I did with mine,
Bought the fender rubber strips and use them on the wheel liner, they worked great.
I may also take a set Joe.
Offline Kenny
« Reply #21 on: August 02, 2011, 07:17:07 PM »
I might be interested in a front pair for the Sky RL
« Reply #22 on: August 02, 2011, 07:58:45 PM »
I dont have any weather strip in my plastic liners and they are both in great shape.
FL
FR
GXP
« Reply #23 on: August 02, 2011, 09:06:25 PM »
You mean the rubber along the top of the front fenders?  :idk:
Wouldn't they be too thin?
Offline MARVIC 1
« Reply #24 on: August 02, 2011, 11:00:13 PM »
I notice some where that someone took the screws off the wheel liner and replace them with push fasteners, the ones that holds the trunk liner in place....... I have 2 extra sets for the front an 1 extra for the rear that I was able to buy at $20 each. Will be replacing the front with new liners and was thinking of using the push fasteners idea....
