Author Topic: HD Sway Bar End Links  (Read 2136 times)
« on: June 14, 2014, 03:59:20 PM »
Just ran across these and thought I'd post.  These look like nuts and bolts compared to others HD SB end links that are cast or welded.
http://bwoodyperformance.com/product_info.php?cPath=64_26&products_id=60&osCsid=lnhhugfexuqkuxnz
Pontiac Solstice Upgraded Sway Bar links
Here they are our own version of the beefiest sway bar links available for your car unlike the OEM swaybar links that have a connecting rod of a mere 5/16 in diameter pictured above ours, the BWoody sway bar link upgrade are 3/4" in diameter. The BWoody sway bar link upgrade comes with PTFE lined heim joints so they'll never need greasing, and they also come with all new mounting hardware, these are a direct OEM replacment part. This upgrade replaces the front 2 oem sway bar links and the rear 2 oem sway bar links, for a total of 4 upgraded endlinks at this price. These will be powdercoated silver as a default if you choose no powder coating.
$180.00 + $15-$20 for custom color.
Offline CLH
Re: HD Sway Bar End Links
« Reply #1 on: June 14, 2014, 07:12:52 PM »
$180 and they aren't even length adjustable? I'm not sure I see how these are any better than the stock links.
« Reply #2 on: June 14, 2014, 07:18:25 PM »
I'm not sure I see how these are any better than the stock links...
They're shiny?    :idk:
Offline Jim
« Reply #3 on: June 14, 2014, 08:26:40 PM »
They are definitely proud of them! I'm sure if you wanted/needed an adjustable setup that you could buy the heim joints and make a set yourself for a lot less. I don't see the need for these myself.
« Reply #4 on: June 14, 2014, 09:46:47 PM »
These ones go to eleven!
