Here's the tsb that SA is talking about. You might want to verify that your car had this done if it applies to you.
____________________________________
#08-06-04-013: Fuel Gauge Fluctuates on Acceleration or Sharp Turns, Low Fuel Light Illuminated (Reprogram I/P and ECM) - (Mar 4, 2008)
Subject: Fuel Gauge Fluctuates On Acceleration or Sharp Turns, Low Fuel Light Illuminated (Reprogram I/P and ECM)
Models: 2006-2007 Pontiac Solstice
2007 Saturn Sky
2007 Daewoo G2X
Condition
Some customers may comment on fuel gauge fluctuation on acceleration or sharp turns when their fuel gauge is at or below 1/4 tank level or above 3/4 level. The needle may fluctuate between 1/8 and empty and eventually turn the low fuel light on. The needle will return to proper level after a few seconds.
Correction
DO NOT replace the fuel tank module or the fuel level sensor.
Technicians are to reprogram the I/P and ECM simultaneously using Sequential Programming.
