Author Topic: Big Brake Kit or Upgraded Pads and Rotors?  (Read 34232 times)
Re: Big Brake Kit or Upgraded Pads and Rotors?
« Reply #50 on: September 17, 2015, 09:45:40 AM »
Are the Boxster calipers the only choice for Vinnie?
« Reply #51 on: September 17, 2015, 09:48:59 AM »
But OEM rotors & brakes look rather dorky w/20 wheels.  :devil:
Offline VinnieRL
« Reply #52 on: September 17, 2015, 10:02:23 AM »
I'm on stock wheels.
DDM I/C Pipes, OCC, Shifter, Adapter & Boot, Silicone Hoses, T-Bolts, trunk & hood lights
Werks I/C, Radiator, Backbone & Swaybars
reBar
K&N CAI
MF Catback
Solo Race Pipe
3bar MAP w/ ZZP Tune
Windrestrictor & Lit Sills
Heated Seat
Quaife
« Reply #53 on: September 17, 2015, 10:16:06 AM »
20" wheels look dorky on a kappa.
« Reply #54 on: September 17, 2015, 10:47:52 AM »
I have to agree.
That the brakes look small on a stock car isn't so much to do with them actually being small (they're not) its the fashion driven trend to ever larger diameter wheels (to the detriment of braking performance, BTW).
No real need for a car tire bigger than 15" or 16".
« Reply #55 on: September 17, 2015, 10:57:00 AM »
V8s with less than 260HP
Tires larger than 15" are unnecessary?  Tires????
 :idk: :idk: :idk: :idk:
That would require rims smaller than 15" which would cause all sorts of suspension clearance issues on modern cars, bottoming out, body damage
The more you type, the more credit you lose in my mind.
It's 2015 not 196x
« Reply #56 on: September 17, 2015, 11:01:03 AM »
Nevermind, I always forget how judgmental people are.
« Reply #57 on: September 17, 2015, 11:03:31 AM »
Elff stop being intentionally obtuse.
The switch (not on Kappas, but as a general trend in all cars) to larger diameters was largely driven by fashion. In terms of performance all you need is something in the 25-16"range.  I said nothing about 15" tires on a Kappa.  I said CAR tire, not KAPPA tire, but I'll try to be a bit more explicit next time so the hard of understanding can keep up.
Offline VinnieRL
« Reply #58 on: September 17, 2015, 11:25:13 AM »
I think we hit this point awhile back but......
reBar
K&N CAI
MF Catback
Solo Race Pipe
Heated Seat
Quaife
Offline VinnieRL
« Reply #59 on: September 17, 2015, 11:27:04 AM »
reBar
K&N CAI
MF Catback
Solo Race Pipe
Heated Seat
Quaife
« Reply #60 on: September 17, 2015, 11:31:49 AM »
Absolutely
I am just trying to show that a lot of the posts are based on outdated opinon
So now Kappa's aren't cars?
 :idk: :idk: :idk:
Your thought process is stalled in the 1960's
[and your high opinion of what you think is incorrect about all modern vehicles that don't fit your optimal mold for a car]
Emissions, Safety standards, increased engine performance, increased braking, increased handling and passenger comforts have evolved past your level of thinking. These new technologies [And REQUIREMENTS] have resulted in heavier vehicles.    These heavier vehicles require a certain size tire to support the weight and at the same time have comfortable and safe handling.
15-16" tires will not work on most vehicles, but 17-18" are needed.  I will admit 20" "AFTER MARKET" wheels are mostly chosen for visuals, but the purchaser of those are free to spend their money as is.
What's absolutely hilarious, is this current argument of yours completely contradicts your previous statement about how important good tires are.
Larger diameter tires can support a wider surface area, with a sidewall ratio that leads to increased handling and braking with adequate sidewall stiffness.
You are all over the place and floundering at this point.
Just give up.
Modern engineering has eclipsed your narrow viewpoint of what is necessary on a car.
« Reply #61 on: September 17, 2015, 01:14:24 PM »
« Reply #62 on: September 21, 2015, 02:22:20 PM »
Clint I don't remember at this point.
TS - Sometime you just have to let people know
