Author Topic: Wilwood brake calipers go tick tick on turns  (Read 1423 times)
Offline DragonSolGXP
« on: January 28, 2016, 12:13:00 AM »
Hi,
I installed a set of wilwood brake calipers a number of years back and never solved this problem. I was wondering if anyone experienced it.
At slow speeds, turning into a drive way, if I crank the steering wheel all the way to the right I hear a tick tick tick coming from the wheels. It's only when it's fully cranked so I'm not that concerned. Just curious.
Has anyone experienced this?
Re: Wilwood brake calipers go tick tick on turns
« Reply #1 on: January 28, 2016, 07:10:12 PM »
Check the routing of your braided lines. May be hitting inside of the wheel when at full tilt.
« Reply #2 on: January 29, 2016, 11:52:18 AM »
Hi,
What kit do you have and what calipers? There are anti-rattle clips in most of the Wilwood calipers, there is a possibility that your anti-rattle clips have come loose/missing/broke. That will cause the pads to click back and forth, that might be your noise. Also, make sure to check that the 3 bolts that hold the hub to the upright are tight while your down there checking things.
Hope that helps,
Dave
