Author Topic: Hydrographic clear coat peeling  (Read 1809 times)
« on: May 12, 2016, 08:05:52 PM »
I meant to address this issue years ago. Has anyone experienced the clear coat peeling/ lifting away from the graphic underneath? Is there a way to fix it without having to redo the whole part that was dipped? I have this happening only on the passenger side side skirt of Norm's side skirts he dipped for me prior to delivery. I was debating on carefully cutting away the clearcoat that is peeling/ lifting and just spraying new clearcoat. I'm at least hoping it will make the imperfection less noticeable.
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
Re: Hydrographic clear coat peeling
« Reply #1 on: May 14, 2016, 09:53:27 PM »
Hello, sounds like you are on the right track. May try some Clear Bra 3M also should protect it better from those chips, that tend to start peeling. Thanks from Norm
