Author Topic: Boost Controller?  (Read 2783 times)
Offline Excelsior
Boost Controller?
« on: May 20, 2009, 06:03:17 PM »
Is there a boost controller I can add to a GXP with the Wester's Race Tune?  Autocross kicked my a$$ this weekend with the instant 25psi boost.
Re: Boost Controller?
« Reply #1 on: May 20, 2009, 06:05:12 PM »
Excelsior,
Try contacting Dave at Dejon. He sell boost controllers and since he also is an authorize Westers reseller he should be able to set you up.
« Reply #2 on: May 20, 2009, 07:01:41 PM »
A boost controller wont fix anything, you need to alter the tune to suit your needs.
Offline Excelsior
« Reply #3 on: May 20, 2009, 08:17:57 PM »
All I want to do is turn it down about 8 or 9 PSI during autocross.
« Reply #4 on: May 20, 2009, 11:12:02 PM »
That will make you uncompetitive, get some sticky tires or simply don't floor it all the way.
« Reply #5 on: May 21, 2009, 06:25:58 AM »
 A pretty easy and legal solution is back off the wastegate rod, it will reduce boost and after you can just reset it, it will make boost come in later and not as hard.
« Reply #6 on: June 08, 2009, 09:00:46 PM »
Ok lead foot,I had the same problem when I first started autocrossing. Ideally try to learn to be  a smoother driver. Smoother is faster or Buy a Hahn adjustable Blow off valve which can adjust when the boost kicks in to your driving style ie- boost delay it works. This allows you to keep your power and boost or if you want no delay in boost you open it up more like for drag racing. Best of all it is hand adjustable and it is easy to install Good Luck Graywolf
« Reply #7 on: June 10, 2009, 01:38:12 AM »
Get the sprint booster, you won't have to touch the gas pedal at all and you will be doing 100MPH LOL :)
