Author Topic: Threw Code this weekend need help. :Resolved  (Read 1224 times)
Offline redragon
« on: January 17, 2010, 11:25:39 PM »
Need some help.
Went for a weekend drive and on the way home the cel light came on.
Checked with my dash hawk and this code (P0315 Unknown) came up.
Anyone by chance know what it is.
The car ran fine just had the cel light come on after i filled it up for the trip home. Check the gas cap and it was tight.
Some one help me on any ideas of what it may be..
I checked on this site.
OBD-II Check Engine Light Trouble Codes
Found this (P0315 Crankshaft Position System Variation Not Learned)
What does that mean.
« Last Edit: January 29, 2010, 09:42:59 AM by DeepBlueGXP »
Offline LiquidPT
  • TechHead
    • LiquidPT's website
Re: Threw Code this weekend need help.
« Reply #1 on: January 17, 2010, 11:52:56 PM »
is this by any chance a new or upgraded PCM? Seems like you need to do a crank learn with a new PCM..
LiquidPT aka Matt
driving Black Sun
« Reply #2 on: January 18, 2010, 09:28:44 AM »
The P0315 code means that the crankshaft position needs to be relearned, usually this happens when swapping in a different ECM, it is really simple to do the relearn with a dashhawk, or the dealer can also do it, and it only takes a couple minutes to do.
With the dashhawk here are the instructions for the relearn:
1. Be sure the engine coolant temperature is at LEAST 158 degrees F. The DashHawk will check and will not let
you perform the procedure if this condition is not met.
2. Set the Parking Brake and make sure the hood is closed.
3. Turn the engine off for at least 10 seconds.
4. PLACE YOUR FOOT FIRMLY ON THE BRAKE. This is VERY important, as the procedure will NOT
work if you do not have the brakes firmly engaged!
5. Go to the Diagnostics Menu->GM Commands->CASE Relearn menu on your DashHawk.
6. Start the vehicle and let the idle stabilize.
7. Follow the prompts on the DashHawk screen. When ready, hit ENTER to initiate the process.
8. When the DashHawk tells you to, steadily rev the engine up to approximately 4000 RPM until you feel the engine
stutter or “top out”.
9. IMMEDIATELY back off the throttle and let it return to idle.
Hope that helps!
Dave
Offline redragon
« Reply #3 on: January 18, 2010, 02:02:24 PM »
Thanks for the reply Liquid and Dave.
Didn't its not a new pcm, same one used when i installed the Stage 2 S/C but didn't get the cel at that time, and that has been at least 2 or 3 months now. :idk:
Will do the crank relearn tonight.  Hope it works.
Thanks again.
 :thumbs:
Offline redragon
« Reply #4 on: January 18, 2010, 08:36:42 PM »
Well got home and tried the relearn.
Took me a couple of tries but it worked. :yay:
Thanks all for your help.  :thumbs:
Dave your the man. :urock:
Now i can get back on the road.  :drive:
