Author Topic: audi theme around fog lights  (Read 1362 times)
DarkSlySol
« on: February 10, 2010, 05:46:31 PM »
I gave a try at the audi theme, around the fog lights came out pretty good. Still debate if i should go all the way around the fog light housing. I also put a strip at the base of the head lights but its kinda hard to see because of the brightness of the HIDs.
Offline amo
Re: audi theme around fog lights
« Reply #1 on: February 10, 2010, 06:46:19 PM »
I hope you have projectors in the headlights, otherwise the light is going every where.  This would be a reason for the light strip being hard to see.  Try putting the OEM bulbs back in and see if you can see the strip.  The fogs look good.  Hope you achieve what you want with the headlights
DarkSlySol
« Reply #2 on: February 10, 2010, 07:47:20 PM »
I have projectors for the fogs, but not for the heads. You can see the strips but im not expectin much brightness, they were only a $1 each lol.
Offline amo
« Reply #3 on: February 12, 2010, 01:26:01 PM »
You have to be killing on coming traffic with your headlights.  I know I would hate to pass you going the other direction.  Put projectors in your headlights and you will see your strip.  Atleast do it the right way if you are gonna get HID bulbs or the headlights.  The OEM headlight setup is not meant for HID bulbs.
