Author Topic: Help pick my turbo  (Read 2051 times)
Help pick my turbo
« on: March 13, 2010, 06:01:01 PM »
So as many of you know my LNF engine is built to handle up to 800 to 900hp, my trans/diff are not.{stock]  This car is not set up for drag racing but High Speed Driving events{Road Racing tracks] Please submit your thoughts/brand/model # etc. on a turbo
Re: Help pick my turbo
« Reply #1 on: March 13, 2010, 06:07:57 PM »
Bullseye Borg Werner S252 Extended Tip for 400-450 hp for a nice street setup.
Bullseye Borg Werner S256 Extended Tip for over 500 hp for a monster :devil: which will be still ok for street driving if you plan to improve fuel system.
Check the ZZP dynos with these turbos on LNF.
My general opinion: there many newer turbos on the market which are better than Garret.
« Reply #2 on: March 15, 2010, 09:11:19 PM »
I am reading about the Bullseye BW S256. It is really confusing to understand all the data/compressor wheels and all the choices on just one model.  Called Borg Werner and left a voice mail explaining what I needed with one of the tech advisors. Awaiting a reply.
« Reply #3 on: March 16, 2010, 04:24:32 AM »
Graywolf I think you should get in touch with Bullseye for info about these turbos: http://www.bullseyepower.com/S200.asp
Also for more info of these turbos on LNF you can read ZZP experience on LNF Cobalt:
S256 - http://www.cobaltss.net/forums/showthread.php?t=192648
S252 - http://cobaltss.net/forums/showthread.php?t=200854
Offline joshmass
« Reply #4 on: March 23, 2010, 11:42:33 AM »
I went ahead and bought the S256ET for my build up. If you do choose something else it would be awesome to see the side by side comparison.
