I am working with Trifecta on a custom tune for my Sky RL. I have the FP68HTA turbo kit from Dejon installed and am up to 22 psi on 91 octane so far. Everything is OK, except that I am running into a bog, up to a second long, when driving hard (near redline shifts). The bog happens in the 1-2 upshift and starts after I am done with the shift and fully depressing the go pedal. Then the turbo spools back up and off I go. At the same time, the CEL blinks and I get P0300, P0302, and P0303 which I think are misfire codes. I tried a no-lift-shift to see if the bog was wastegate/spoolup related but this only made the bog worse. Trifecta is dedicated to working on this but has not figured it out yet. Anyone have a clue what might be causing this?
