Author Topic: Looking for a HPT log with NLS  (Read 4470 times)
« on: May 11, 2010, 07:26:46 PM »
Does anybody have a HPTuner log with No Lift Shift?
If I'm reading correctly my logs there is a huge delay between pedal sensor 100% and until throttle position is 100% open.
So my Pedal sensor reaches 100% at 00:12.719 (check status bar of the window) and my throttle reaches 100% at 00:13:860, which makes a 1.1s delay, this is a 1-2-3-4 gear log.
Also notice the delay of boost and airflow between shifts.
I'm trying to reduce my drag racing times and wondering if I can find a solution to shorten these gaps with NLS.
Offline shabby
Re: Looking for a HPT log with NLS
« Reply #1 on: May 11, 2010, 07:39:40 PM »
That's totally normal, the ecm slowly opens the throttle at wot for whatever reason. With nls its open all the time when you get the shifts right.
« Reply #2 on: May 11, 2010, 08:12:15 PM »
So my log readings are correct?
Damn ECM  :goat:
I'm trying to see if the boost and airflow will have shorter drops if the throttle blade is kept wide open between shifts.
« Reply #3 on: May 11, 2010, 08:28:26 PM »
Cut the wire and install a manual throttle :) GM book suggests that for drag racing cars
« Reply #4 on: May 12, 2010, 06:08:49 AM »
I can log .5-.6 close throttle on the 2.4l when quick lifting of the pedal. Kiss the rev limiter which closes the throttle and it is a one second shift.
Norm
