Author Topic: Painted Engine Cover  (Read 7052 times)
Offline River City Sol
« on: September 27, 2010, 06:01:17 AM »
I am trying to decide on which way to go, Painted engine cover ( to match my Body color ) or strip it out and go with Powder covered Chrome parts from DDM. For those who have chosen to paint your covers, what type of paint did you use to hold up to the heat and since it is on a plastic type part was it special to prevent cracking due to plastic flexing over time ?
2007 Envious
Drilled & slotted Rotors
Razzi Spoiler
Solo SQR-2 Center Duals
ASAP Light Covers
Fujita CAI
B Cool Billet Grilles
Debadged
Re: Painted Engine Cover
« Reply #1 on: September 27, 2010, 11:09:12 AM »
I used Caliper brake paint on mine and it held up fine. I suggest you paint your cover 1st,if you like it then keep it[Cost few bucks] If not the try a after market cover. I currently have a Dejon chrome cover that looks ok but the metal is to thin and deforms if not tightened symetrically.
Offline rich71
« Reply #2 on: September 27, 2010, 11:12:51 AM »
i used red pinstripe tape to "fill in" where groves are on the cover..they have stuck just fine...i then used flat black engine paint, sprayed into a cup then painted the "loover" egdes so they look functional - it isn't alot of pop, but subtle and looks neat....sorry I don't have a picture
2007 Midnight Blue Redline
Manual Trans
Westers Race Tune
Hahn Intercooler
GMPP Catback Exhaust
ReBar
DDM Race Backbone Brace
JPM Shifter
Sprint Booster
K&N Filter
Stubby Antenna
BMW LiftPucks 4the BLIND
Offline GXPsy Rose
« Reply #3 on: September 27, 2010, 03:30:02 PM »
Might want to talk with "Rogue", he's done several and is experienced in auto painter/detailing
GXPsy Rose
2008 BRAZEN GXP w/GMPP tune
Ordered: June 1st 2007 & Delivered: July 20th, 2007
I LOVE MY CAR
NASSOA:  Founding Member #52
Go N.A.K.3.D..
"Life's too short not to drive a fun car"
« Reply #4 on: September 27, 2010, 05:28:37 PM »
Black gloss engine paint. The stuff is thick and will cover most blemishes from the rattle can.  :)
Offline Va_Sky
« Reply #5 on: September 27, 2010, 06:09:17 PM »
I have both the DDM painted Valve cover with the coil cover and I had the Plastic engine cover painted by a local air brush artist... Here are the results.
08 Redline Midnight Blue
Black/Black,
Three Pedals (Do They Make'm Any Other Way?),
Spoiler, Chrome, Monsoon,
Opel GT Antenna, V2 Windrestrictor,
JPM Embroidered Visor Covers and Console,
GM Stage 2
DDM - Backbone, Pro-Beam, Fuel Filter, Powder Coated Valve Cover,
Coil Cover, Charge Pipes, Intercooler, Big Wheel Turbo
High Country Solstice Sky Club
« Reply #6 on: September 27, 2010, 07:28:50 PM »
Here's mine. Continued thanks to Deepbluegxp. He can tell you what he uses. He did an excellent job.
« Reply #7 on: September 30, 2010, 12:41:57 PM »
I used standard auto paint for smartin's, mine and deedle's.   Heat resistant paint isn't required.  Use your imagination and have fun.  Post pics when you're finished.
Offline tazzman
  • with new paint
« Reply #8 on: September 30, 2010, 02:35:29 PM »
What auto place do you get the blue mobil one oil cap and any other caps?
King Penn, W.R.
ASAP Fuse box cover
ASAP Fog light cover
ASAP BU light cover
Debaged
Shorty antenna
Magnaflow catback 3''
New Paint
« Reply #9 on: September 30, 2010, 02:40:54 PM »
Search for MRZ.  they do a custom job and they are not cheap.  >$100 for the set
« Reply #10 on: September 30, 2010, 05:04:32 PM »
Actually $200 for the set in polished aluminum, plus shipping.  Or $240+ if anodized (red/blue/black).  Ouch!
« Reply #11 on: October 01, 2010, 06:15:21 AM »
Stuart - LOVE the flames!!!
Offline Va_Sky
« Reply #12 on: October 01, 2010, 09:17:59 AM »
Thanks Karen....
Black/Black,
GM Stage 2
Offline Houstice
« Reply #13 on: October 02, 2010, 04:31:06 AM »
Here is my engine cover that I had painted at a local shop. Matches my body color.(Brazen Orange metallic)
« Last Edit: February 09, 2011, 07:14:23 PM by Houstice »
« Reply #14 on: October 02, 2010, 10:09:48 AM »
Very nice! :thumbs:
Offline SolPainter
« Reply #15 on: October 02, 2010, 09:26:59 PM »
I used Krylon Fusion paint for plastic.  Used Chili Pepper Red and a coat of Fusion Clear on top.   Holds up well and easy to use.   I sanded with 2000 grit first so the paint would hold better.  Be sure to clean with a solvent before painting.  I cleaned many times with Acetone and Alcohol.  Be sure to use lint free rags and that all the lint/dirt is off the parts.
Check out the pictures "under the hood"
http://picasaweb.google.com/107570407804836412180
« Last Edit: October 03, 2010, 02:26:42 PM by SolPainter »
