Author Topic: Fog Lights Inop  (Read 1792 times)
Offline SolNut
Fog Lights Inop
« on: May 05, 2011, 04:29:54 PM »
Went down the road to help out a non-forum retired Army guy that just got his '08 GXP back via the last DIVORCE settlement  :banghead: (Was #5 so maybe it will be the last one).  :yay:
  He had not seen it since January and the whole car needs some TLC.
His Fog Lights will not light.  Checked Fuse 53, it was OK, Swapped Relays 54/55 no difference.
He has 12 Volts at the Fuse, but does not see anything at the connector for the Fog light (both)
Dash indicator light comes on when pushed.  High/Low beam position makes nary a difference.
Has anyone seen/heard of any problems in this area?  :huh:  :idk:
Thanks-Steve
 :drive:
 :drive:
Re: Fog Lights Inop
« Reply #1 on: May 05, 2011, 04:49:51 PM »
Check if there is 12V at the output of the relay.  If not, it could be a BCM problem (relay is activated via BCM, not directly from switch).
If the relay output is live, then it must be a wiring continuity issue.  Maybe the wiring was trapped and cut somewhere.
Offline SolNut
Re: Fog Lights Inop
« Reply #2 on: May 05, 2011, 04:52:37 PM »
Thanks for the help, I might get another look/see this WE.  :thumbs:
Re: Fog Lights Inop
« Reply #3 on: May 05, 2011, 05:33:14 PM »
I had the same issue.  It was a loose wire under the fuse block under the hood
Offline SolNut
Re: Fog Lights Inop
« Reply #4 on: May 05, 2011, 06:17:37 PM »
Thanks DB, I'll get after it when I can.   :thumbs:
Steve
 :drive:
Re: Fog Lights Inop
« Reply #5 on: May 05, 2011, 06:21:15 PM »
I had a similar problem with mine. A long time ago. I'll try to find the thread on SF and post the solution here just in case it will help you.
Re: Fog Lights Inop
« Reply #6 on: May 05, 2011, 07:25:35 PM »
This is how they fixed it on my Solstice way back when:
CHECK CONNECTOR C3. FOUND WIRE 2234 NOT IN CONNECTOR E5.
Hope this helps.
Offline SolNut
Re: Fog Lights Inop
« Reply #7 on: May 05, 2011, 08:55:07 PM »
TY, TYVM  :urock:
Steve
 :drive:
Re: Fog Lights Inop
« Reply #8 on: May 05, 2011, 09:11:11 PM »
That is near record time for a solution.  Compliments to all that posted factual and helpful information.  Exactly the kind of posts we need more of.  Since i am totally incapable of posting anything helpful, I must applaud when someone does.  If you need a laugh, let me know, that's my specialty.  Oh, and nudity, but that is in another part of the forum.
Offline EarthNTX
Re: Fog Lights Inop
« Reply #9 on: June 28, 2011, 09:11:05 PM »
Yep..I can't offer much help, just praise for all the help we're getting here. :urock:
Ride it like you mean it.
