Author Topic: Replacement calipers  (Read 2864 times)
Offline RufusMacblorf
« on: March 20, 2012, 05:58:38 PM »
A while ago a vendor (I think it was DDM) was working on some bolt-on, lightweight, 4-piston calipers.  They sounded pretty appealing.  Does anybody know what happened?
Offline Racer_X
Re: Replacement calipers
« Reply #1 on: March 20, 2012, 07:29:39 PM »
They are working on re-introducing them to the solstice/sky public!
There are other options as well:
The Cobalt SS brembo calipers work with the Solstice/Sky- but you cannot retain your stock wheels without a spacer.
The Boxster (Non-S model) calipers will work as well, but you'll need to make your own bracket- if you need dimesions- hit me up.
Both of these upgrades are less than 600.00
If you're a big spender, contact TCE for about 1200~1500 you can upgrade your rotors, calipers, lines and all that.
2008 Sly GXP (Z0K) Custom Tune, Dejon Precision 5557B Kit, Wiseco/ARP/K1 Built Bottom End, AEM Meth Injection, SPEC Stage III Clutch, DDMworks Backbone, Kappasphere ReBar, DDM Crossbrace, Custom Front Splitter, HKS SSQV, NORMS ZR-1 fenders, Cobalt SS BBK.
414rwhp/ 436tq @ 26.5psi
« Reply #2 on: March 20, 2012, 08:07:41 PM »
Not a big spender, so the Cobalt calipers sound interesting.  I have TR Motorsports C2 wheels, which seem to have more clearance than stock, so I might be okay.  On the other hand, if DDM comes out with a product, I'm sure it'll be well tested specifically for our platform.
Offline Racer_X
« Reply #3 on: March 20, 2012, 08:19:54 PM »
All of these options have been tested and do exactly as designed- but the major deciding factor for me was availability- and other than the need to have to make brackets, the Porsche setup has been the cheapest- you'll spend more money on the brackets than anything else.
« Reply #4 on: March 20, 2012, 09:49:00 PM »
I have the TCE kit front and rear.
It's an amazing setup and shaves 22lbs of Unsprung weight off the front and maintains the parking brake in the rear.
As its a production kit, it's always available
