Author Topic: 18x9 O.Z. Ultraleggeras installed!  (Read 4408 times)
Offline stealthsky
« on: July 15, 2009, 08:49:31 PM »
Well, I got my new 18x9 O.Z. Ultraleggera wheels installed (all four corners) with 275/40/18 Nitto Invos. *after further investigation Ive noticed slight rubbing in the rear (rubber to wheel well). It appears that it happens during hard cornering because there is alittle space when straight, I checked after a nice spirited drive and tires were still warm.
  The rear wheels touch the upper control arm while on jacks but after settling on the ground have about a fingers distance between. Souldnt be a problem unless I catch some air.
The tires provide a whole lot of traction.  :drag:I can get on it alot more with out worrying about the rear catching up with me or swinging around during turns.
All I have are cell phone pics for now but after I get back from Alaska in about 4 wks Ill get better ones.
« Last Edit: July 15, 2009, 10:12:18 PM by stealthsky »
2008 Sky Redline
Mods:
RPi Gt exhaust
RPi Race Downpipe
GMPP Intake
GMPP Performance Upgrade Kit
DDM Race Backbone
18x9 OZs W/ NITTO INVOS
Best 1/4 mile time
13.688 @104mph (altitude of over 3000')
Re: 18x9 O.Z. Ultraleggeras installed!
« Reply #1 on: July 15, 2009, 08:54:48 PM »
Boy those look nice, I would love to have such things on my black gt also.
I bet you will improve that 13.6s with those shoes. ;)
« Reply #2 on: July 15, 2009, 09:00:22 PM »
need to lower the car now
Offline stealthsky
« Reply #3 on: July 15, 2009, 09:03:24 PM »
Thank you.  Im thinking theyll help bring the times down.  They are wider, grippier, and lighter than stock. The 13.6 came with a 2.3 60'  so Im thinking I can get that down quite a bit.  Ill find out hopefully August 19 when Im able to race closer to sea level.
2008 Sky Redline
Mods:
RPi Gt exhaust
RPi Race Downpipe
GMPP Intake
DDM Race Backbone
Best 1/4 mile time
Offline stealthsky
« Reply #4 on: July 15, 2009, 09:04:46 PM »
eventually I probably will but it is not as bad as the pic. I literally just got it off jacks when I took the pic (if you look closely where the rear jack point is, you can see where the jack sank into the ground a little, was only 104*that day) .  It sits alittle lower now.
2008 Sky Redline
Mods:
RPi Gt exhaust
RPi Race Downpipe
GMPP Intake
DDM Race Backbone
Best 1/4 mile time
Offline stealthsky
« Reply #5 on: July 15, 2009, 10:10:18 PM »
Added a correction to the first post. Looks like I may be adding a spacer to each rear wheel.
2008 Sky Redline
Mods:
RPi Gt exhaust
RPi Race Downpipe
GMPP Intake
DDM Race Backbone
Best 1/4 mile time
Offline Yamatr3
« Reply #6 on: July 15, 2009, 10:12:08 PM »
If you lower it in the future, it will give you a little more clearance.  You should be totally fine though.
« Reply #7 on: July 15, 2009, 11:04:41 PM »
Oh no it won't. Been there, doing that. As one lowers the car the camber goes more negative thus leaning the tires IN towards the inner fender well sheet metal !!!!!!!!!!!!! Hammer time.
