KappaPerformance is the only forum withZERO ADS. We need support to continue this, consider premium.KP does not send emails or sell your info. Please email KappaPerformance@gmail.com for account help.
Damn Dave.....I think this car is from my friend in Mexico!owner Jose Antonio!!! He will be happy after you do your magic on this monster build!
Looking forward to ur updates!
Me too! Please finish my intercooler first though.
Funny you say that, Matt is just finishing it up now! It will be leaving here on Thursday, thanks!
Perfect timing! I just received the UPS shipping information as well. Thanks a bunch and have a Happy New Year!
Does this mean the stock K04 is named Davy Crockett or Jim Bowie?Subscribed
Man I hated when people called me Davy Crocket when I was little
I wonder how many young people here don't know who Davy Crocket is.
Davy Who????? (like you didn't expect that from someone)
For those of you who are curious - project "Alamo" was named because the owner has a bunch of Alamo Rental Car franchises in Mexico -
Now that would be awesome.DaveAny hints on what parts you will be using?Specifically the turbo choice
Maybe a 200 rpm advantage over a similar sized GT garret and I would not call that "way" faster.HPT logs have been posted to back this up as have 60-100 times that only vary by .2-.3 of a second Similar sized EFR and GTX model Garret turbos will be even closer if not almost identical.
For sure the EFR7163 is the winner here. Same or better power, and better response.
And the GTX3076R test with a .82AR housing. Much laggier and only a bit more power. Again, is 20WHP worth it?
Since the dyno is very controlled, and a high loaded run, in all these tests the super light Titanium Aluminide turbine wheel doesn’t come into play at all. What this does show is the turbine wheel and compressor wheel design is a notch up over the Garrett GTX stuff. From what I have seen Borg Warner has designed a turbo that does what they say it should. It makes more power and spools faster than the GT3582R.The dyno conclusions do not match what I “feel” on the road. On the road, I feel like [the 7670] is much more lively than the GT or GTX3076R. Its interesting as in some road tests the EFR7670 shows the same spool up RPM as the GTX3076 w.82ar, but it feels so much snappier between shifts light load low RPM shifts. Meaning the normal day to day 2000-4000RPM shifting is about 50% better than it was before. In some logs I notice that the GTX would show say 2-3psi of boost at these really low RPM’s, where the EFR is showing about 5psi. Its only a couple PSI but that makes huge difference in how it feels. You can see this on the dyno graphs where the EFR is making more TQ at 2000-2500.
