Author Topic: Tip: Tool for removing spring-type hose clamps  (Read 18795 times)
« on: April 13, 2014, 07:05:06 PM »
Probably most of you already know this, and it's only me that used to struggle with getting the spring-type (or "constant pressure") hose clamps off with regular or needle nose pliers, but in case you didn't know...
I had to go to my daughter's college yesterday to fix a bust coolant hose on her car, an older Honda Accord.  While researching the issue I found a couple of videos on youtube where one guy was using bent-tip pliers to remove the hose clamps - these were the spring-type (or "constant pressure") clamps.  So I stopped off at Harbor Freight to get a cheap pair (less than $5 - get the 90 degree bend ones, not the 45 or 60 degree).  Well, I have to say they were worth their weight in gold.  Made what I've usually found to be a really frustrating job, extremely easy, so just passing this along.  Now I know that there are special pliers available for just this job, but these are cheaper and usable for other things as well.  These are what I mean, available from HF, many parts stores, Sears etc...
... and the clamps I'm talking about...
Re: Tip: Tool for removing spring-type hose clamps
« Reply #1 on: April 14, 2014, 01:11:41 AM »
Always a great thing to have around.
Offline crisco
  • My Precious!
« Reply #2 on: April 14, 2014, 06:01:34 AM »
Wished I researched last week. broke two of them. One replacing the upper radiator hose, Red One, and the small hose the one that we take off to Burp the Kappa!
Offline blackbirdracing
  • Kappa Newb
« Reply #4 on: April 14, 2014, 07:46:16 AM »
Thanks guys, looks like I need to go shopping.
« Reply #5 on: April 14, 2014, 08:58:34 AM »
I use these...  Its what's your supposed to use.
http://m.sears.com/index-g.html#/productdetails/00947390000P?partnumber=00947390000P
Yes.  Like I said...
[...]  Now I know that there are special pliers available for just this job, but these are cheaper and usable for other things as well.
  • Kappa Newb
« Reply #6 on: April 14, 2014, 09:01:23 AM »
Yeah, wait til you find a clamp that's turned around the wrong way and you can't get on them with those pliers.
I have used angled needle nose forever on these. They work good.
But these cable ones have a locking position that just makes it so easy.
