Author Topic: FS: One of custom turbo kit for the sky/solstice!  (Read 4199 times)
« on: August 25, 2014, 03:31:55 PM »
One-off custom turbo kit for the sky/solstice!
- Borg Warner turbo s200sx
-  custom exhaust manifold 304 ss equal runners
- 3" downpipe
-  turbosmart 38mm wg
- synapse Recirculating DV
- all necessary lines included
 Kit can easily go 450whp.
Slightly used (only on dyno).
Only $2000 plus shipping.
if interested, or have any questions pls txt me at 570-647-6070 (Antonio)
« Last Edit: August 26, 2014, 02:41:47 PM by SKY888 »
Re: FS: One of custom turbo kit for the sky/solstice!
« Reply #1 on: August 26, 2014, 12:42:16 AM »
Will this fit an Infiniti FX?
« Reply #2 on: August 26, 2014, 02:42:11 PM »
Borg Warner S200SX:
1.22 A/R. - Compact, high-flow S200SX model with recirculation-type compressor cover
56/76mm, Extended Tip compressor wheel, with peak flow of 60lb/min.
Compact, .47A/R Compressor cover is 4” hose-type inlet and 2” hose-type outlet, and is machined for a recirculation groove, which can help to ‘broaden’ compressor efficiency.
70/61mm, highly-responsive turbine wheel, cast in Inconel.
The single-scroll has the ‘T31’ style discharge flange, and is identical to the Garrett T31/T04E hybrid, as well as the GT-series that use the same casting.
The turbine inlet flange bolt patterns are identical, and are traditionally referred to as 3.38 x 1.75, or ‘standard’ T3.
Offline miuwdawg65
« Reply #3 on: August 28, 2014, 12:01:26 PM »
With enough money, anything will fit!!!  :poke:
"Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."  ~ anonymous
« Reply #4 on: September 03, 2014, 10:03:54 PM »
I'm not sure if this is the right thread for this but...
I'm sitting in the PHX airport with a 2.5 hour layover. I've challenged the bartender to make Rye drinks I've never had. So far I'm up 2-0
He must be an amateur. He started with a Manhattan and went to an Old Fashion. Does he think I'm a ROOKIE?
Offline crisco
  • My Precious!
« Reply #5 on: September 04, 2014, 06:01:07 AM »
I think that you had 1 too many Rye's!!!
My Precious! 2007  Solstice GXP, Aggressive, Santana Cup Holder, Beachparty Fuse Box Cover,DDM Backbone Brace, DDM Performance Probeam, DDM Latin Venom Brace, DDM Oil Catch Can (Red), DDM LNF Intake Tube (Red), DDM Radiator Hose (Red), Wind Restricter, Solo Performance Mach Shorty Exhaust,...more to come!
« Reply #6 on: September 04, 2014, 04:56:04 PM »
We need that plane to take off.
« Reply #7 on: September 04, 2014, 07:11:21 PM »
I'm already back at that same airport! Headed home. Crying over Joan Rivers.
« Reply #8 on: September 04, 2014, 07:51:35 PM »
They have a drink named after her already?
« Reply #9 on: September 04, 2014, 08:11:02 PM »
Yup. It's a high ball glass filled with plastic and silicone.
« Reply #10 on: September 04, 2014, 08:48:16 PM »
Sounds revolting.
« Reply #11 on: September 05, 2014, 10:55:24 PM »
Turbo kit SOLD to ryansalazan!!!!
thanks!
