Author Topic: P2297 (MIL on) and P2626 (Pending) - Looks like I need a new Wideband O2 Sensor  (Read 8441 times)
I set two codes I haven't seen very much on the boards today. I haven't heard of our pre-cat O2 sensors failing much, so I was skeptical.  Unfortunately there doesn't seem to be an easy way to bench test a wideband O2 sensor, so I'm hoping I've arrived at the right conclusion by eliminating all of the connectors/terminals en-route between the sensor and ECM.  I probed both ends of each wire at the terminals with my multimeter and found 0 to .3 ohm resistance (which is negligible, because I see practically that much touching the meter's leads directly to one another).  I didn't go so far as a "wiggle and tap test" along the harness, but I'm pretty confident it *just* needs a new sensor.
I pulled the sensor out to take a look, and it doesn't visibly appear fouled in any way.
Wish me luck!  I'll update this thread with results later on in the week after I get the new sensor and install it.
For reference, here are the DTC definitions:
P2297
HO2S Performance During Decel Fuel Cut-Off Sensor 1
P2626
HO2S Pumping Current Trim Circuit Sensor 1
Good luck!
I replaced the O2 sensor on my daughter's Accord, just based on the OBD codes, and that fixed the problem (before that I'd been clearing them and they would come back).  The old sensor looked visibly fine, but it was apparently dead.
Sensor arrived today.  I replaced it, and all is well again.  Not many places stock our pre-cat sensors (the wide-band one).  Either it's an uncommon part, or they just seldom fail.
Good information but yet another that I hope I never need. Thanks for posting the results!
I'm starting to wonder how long it was flakey before it finally gave up the ghost and started throwing codes.  It now idles smoother than it has in quite some time.  Gotta find a place to stretch her legs and see if it no longer stumbles after a full throttle 1-2 shift.  This has been an occasional occurrence for years.
Probably just a bad driver.
I picked up a couple when they were cheap from Source1 (under a different name) I think a few years back $30 each.
Nope, I updated all my drivers.
How do you update a screwdriver?
Offline roxer
Where did you end up ordering it from?
Ordered from rock auto.  It was something like 70 bucks shipped for a Bosch (same as OE).
Move from 18v to 19.2 v
That makes sense, I was thinking maybe we would have to get a more modern vodka.
Well, it seems the Bosch sensor sh*t the bed just over a year later.  I've ordered an NTK on Amazon this time. It should be here tomorrow.  This time around, my indicated air:fuel ratio would max out and stay that way occasionally, and other issues would pop up as a result.  Pretty sure the ECM was dumping a ton of extra fuel in to try and compensate, but I was never in a position to really look at fuel trims when it was going on.  I thought it might have something to do with never cleaning my MAF, and neglecting to clean my K&N filter for quite some time, but the issue came back the next day...  So my guess is the heating element in the replacement sensor was getting flakey.  Hopefully the *new* new sensor gets me squared away again for several more years.
Could something be fouling the sensor?
Last one I pulled out looked completely clean.  I'll pay attention to this one as well.  It's only intermittent at this point, so I'm not sure what to make of it.
best "backyard mechanic" way to see if an O2 sensor is still functional is to hook up a tool so you can see the raw o2 values and artificially richen the air on the sensor. Take a rag and throw some brake cleaner in it. You should see the sensor move from full lean to full rich.
I went through an O2 sensor on my sky when I had it. I also recall ordering the sensor and waiting for it to come in.
In installed the new one today.  It seemed fine on the test drive, but then again so did the other one 3 out of 4 times.  I'll give it a week or so before I claim victory.  I'm monitoring the AFR values with a DashDAQ.
