Author Topic: Has anyone actually solved for the common passenger air bag sensor failure?  (Read 3304 times)
Offline Rockchops
As the title states...everything I read online is replace and calibrate. As parts become harder to find for this car, it's not really a scalable solution over time. Replacement is already about $400 and only comes as a built-in cushion sensor combo.
I have not read anywhere that someone has bothered to diagnose the root cause of the issue. To me it seems like a loose or broken connector throwing a bad signal to the CAN bus and tripping the default error code. Granted the wiring and signals are rather complex as they're going to a can bus but I doubt the actual weight sensor is anything more than a pressure sensor not unlike a truck scale...in which case it can likely be fixed easily (though perhaps not without tearing it apart).
Btw my light popped this weekend :(
Sent from an abacus
Re: Has anyone actually solved for the common passenger air bag sensor failure?
« Reply #1 on: September 07, 2015, 12:08:32 PM »
The root cause has been found and discussed. The sensor array in the passenger seat cushion rips partially through a circuit pathway. There have been attempts by a few of us to repair the sensor array, but to no avail. I have also tried to make a sensor bypass module. That too, failed. Page 16 and on give the most detail to the problem.
http://www.solsticeforum.com/forum/f12/recall-passenger-airbag-sensor-70726/index16.html
« Reply #2 on: September 07, 2015, 12:41:27 PM »
Like Helios said.  Done and dusted: http://www.solsticeforum.com/forum/f12/panssenger-airbag-sensor-75353/index6.html#post1126380
Offline Rockchops
« Reply #3 on: September 07, 2015, 12:58:03 PM »
Thanks guys, did not find either of those threads thanks to a couple hundred threads on "why do I have air bag error". Got some reading to do...will probably try and fix myself because there's no loss here.
Sent from an abacus
« Reply #4 on: September 10, 2015, 10:35:04 AM »
Mine is lit also for a couple of weeks, I asked at the service (not dealership) an electrician to have a look at the sensor and let me know if it needs replacement, I'm waiting the answer.
