Author Topic: Coilovers  (Read 7305 times)
Coilovers
« on: October 18, 2016, 02:21:53 PM »
What coilovers did any V8 swappers go with? Custom spring rates? I will most likely upgrade to BC coilovers sometime after my swap is done. I'm just trying to figure out what anyone else has done. Also, will I need anything else like sway bars or bushings?
Re: Coilovers
« Reply #1 on: October 20, 2016, 07:44:03 PM »
With the extra weight of a V8, even though it's not much, I would think that would justify getting the same spring rates front and rear.
Because you can adjust the height of coilovers, I think you would be more than fine with a set of BC's with stock 7Kg Front and 7Kg rear.
Re: Coilovers
« Reply #2 on: October 21, 2016, 06:50:34 PM »
Ok. Cool.
Re: Coilovers
« Reply #3 on: October 30, 2016, 05:01:59 AM »
So, I pulled the trigger before the sale ends on these:
https://store.bcracingusa.com/products/pontiac
I've never changed to a set of coilovers. The process seems fairly straightforward.  Will these spring compressors be sufficient?
https://www.amazon.com/AMPRO-T70570-Coil-Spring-Compressor/dp/B00A8FNRDY/ref=sr_1_14?ie=UTF8&qid=1477817280&sr=8-14&keywords=strut+spring+compression+tool
Re: Coilovers
« Reply #4 on: October 30, 2016, 07:38:44 PM »
You will not need spring compressor's to swap the entire unit.  Those are only needed if you are removing the springs from the shocks.
GJ put together a nice thread with pictures on how to do this.
http://www.kappaperformance.com/forum/index.php/topic,7280.0.html
Re: Coilovers
« Reply #5 on: November 02, 2016, 01:23:58 AM »
This GJ guy is AWESOME
Re: Coilovers
« Reply #6 on: November 02, 2016, 11:05:34 AM »
Yeah he's not too bad.  You should see his post from when he is waiting at an airport for the next flight.
Re: Coilovers
« Reply #7 on: November 02, 2016, 02:02:24 PM »
He does love animals.
Re: Coilovers
« Reply #8 on: November 02, 2016, 03:34:44 PM »
He does tend to find some odd wild life.
