Author Topic: F/S LE5 LNF Flywheel Bolts REUSABLE Performance  (Read 2098 times)
« on: March 09, 2017, 02:08:35 PM »
I have modified low head flywheel bolts for use with the LE5 and LNF? manual transmission flywheels.  OEM bolts are one-time use Torque-to-Yield.  I really don't like the idea of buying bolts everytime I touch them, so I figured this solution out and confirmed it works for the Kappa platform.
Clearance is very limited with this powertrain so you will note the stock OEM bolts have very low heads. This bolt head is machined down to eliminate the chance of mechanical interference and re-coated black.
No Longer being advertised.  Contact me if you're interested we can talk about your application.  There are some variables to discuss and I am not fully confident they will work on every application.
« Last Edit: April 17, 2019, 06:43:22 AM by Steelmesh »
Re: F/S LE5 LNF Flywheel Bolts REUSABLE Performance
« Reply #1 on: March 15, 2017, 09:39:54 AM »
It's great to have you here Steelmesh as a lifetime supporting member and they all look like great products. I have cleaned up the thread, all the best.
