Author Topic: F/S Kappa Stainless Clutch Hose Kit - The One and Only kit for Solstice / Sky  (Read 9191 times)
I damaged my clutch hose when replacing my clutch, then found out that GM ran out of clutch hoses completely last summer 2016.
  • Improved clutch pedal dynamics, reduced spongy feeling
  • Fittings made from 316 Stainless steel for maximum corrosion resistance and strength
  • O-rings DOT3 / DOT4 compatible, special curing for extreme temperature performance
  • Application: Racing / Off-road
  • Replaces: 24236218
  • Fitment: All 2006-2009 Solstice, Sky with manual transmission
  • DOT3/4 Compatible PTFE lined stainless braided hose is 100% high pressure tested
  • All components Designed and Manufactured in the U.S.A
Price is $109 for the complete kit with both fittings, all o-rings (and spare), and the hose.
Purchase here: http://www.kappadapt.com/
The website is on the 3Dcart platform with an active SSL encryption as expected with any website that handles payment transactions. Paypal payment method is also available at checkout.
alternate Amazon: https://www.amazon.com/gp/offer-listing/B01N7CQDLT
alternate eBay: https://www.ebay.com/itm/2006-2009-Solstice-Sky-Stainless-Clutch-hose-kit-AR5-transmission-2-0L-2-4L/112722117654
__________________UPDATE____________________
Customer inquired about purchasing just a fitting for a swap project, so I have added a new listing so you can buy either fitting individually for swap projects.
These fittings allow you to adapt OEM to -4AN flare fittings.
Master cylinder, single o-ring: to adapt the Solstice/Sky master cylinder to other transmission slave cylinders
Slave cylinder, dual o-ring: to adapt the AR5 manual (Solstice/Sky) to other vehicle master cylinders
Currently for sale $40 for the slave side (AR5 swap guys) and $45 for the master side, both a -4AN standard fitting:
http://www.kappadapt.com/Kappadapt-Stainless-Clutch-FIttings-AR5_p_23.html
« Last Edit: January 09, 2018, 06:53:51 PM by Steelmesh »
It's great to have you here Steelmesh as a lifetime supporting member and they all look like great products. I have cleaned up the thread, all the best.
I suspect that Joe and Steelmesh have worked this out already.  ;)
Joe rocks  :urock:
Welcome Steelmesh!!!
Welcome Steelmesh, interesting products hope you do well
Offline blackbirdracing
  • Kappa Newb
Welcome good sir!!
Offline roxer
Can this be installed without dropping the tranny?
You would indeed need to drop the trans, or at least unbolt and shift the trans back to get at the slave cylinder to remove the clip.
Offline sirwm
something is not right here...
The thread says 'for sale', but I do not see any information on HOW to purchase. ( I did see the price... )
wr
Steelmesh our member of the forum is the sales person, just send him a PM if you want to buy the item.
Thanks I have updated the original post.  You can find them at kappadapt.com or search amazon.com
I originally wasn't sure if I could even post this here, but we worked it out so I can share the links.
Offline Kpleblanc
Do you have these built and ready to go?
Yes I have kits ready to ship
Re: F/S Kappa Stainless Clutch Hose Kit - The One and Only kit for Solstice / Sky
« Reply #13 on: September 28, 2017, 12:19:19 PM »
« Last Edit: January 09, 2018, 06:49:38 PM by Steelmesh »
