Author Topic: NormsFiberglass New Reccesed front Solstice grill  (Read 57465 times)
0 Members and 8 Guests are viewing this topic.
Offline Northern Sol
Re: NormsFiberglass New Reccesed front Solstice grill
« Reply #50 on: April 03, 2017, 12:27:43 PM »
Awesome, dont see any reason the Race mesh grilles that you have won't work. Might have to cut them down a little so they fit through the opening. That Mesh material they use is so tough to cut it's PIA, but everything we do here is a PIA, lol. Dont buy the Kidney grilles I have a set.
Hi Norm,
Are the set of grills you have black?
Gareth
« Reply #51 on: April 03, 2017, 01:29:09 PM »
Tall Craig,
PM sent. I will take them. As per PM need you to ship them to Norm. He will then get them ready and install them on my Coupe at the Nationals!!!!!!
Yahoo!!!!!
« Reply #52 on: April 03, 2017, 01:31:38 PM »
This could well prove to be Norm's most popular mod yet!
Norm, how do these frames fasten to the bumper?
I was wondering the same thing.  Someone correct me if I'm wrong, but aren't the grill tabs molded into the backside of the perimeter of the OEM grills? Another way of saying it is, if you cut out the honeycomb grills, aren't you also removing the tabs?
« Reply #53 on: April 03, 2017, 02:37:35 PM »
I called Norm and had a good chat with him. I asked him about returning my Coupe to stock. He said removing his grills does not damage anything and providing you have an extra set you pop them back in and you are back to stock. That sold me. Now thinking about a rear fascia while I am at Nationals????? If kept stock exhaust and replaced plastic fascia with Norm's in black..........I will let Norm answer about the tabs. Pretty sure they have to be cut off. Hence the need for a second set of OEM grills.
« Reply #54 on: April 03, 2017, 02:43:51 PM »
You're still going to have to trim back the foam bumper padding behind the existing grills in order to make room for the new grills . . .
:thumbs:
« Reply #55 on: April 03, 2017, 03:28:58 PM »
:thumbs:
Good point. Guess I have to live with that.
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #56 on: April 03, 2017, 08:14:41 PM »
:thumbs:
True! though not all the foam and you really can't see it. Yes some will say it has to be there, but in all truth it basicilly just keeps the bumper ureathane in place. That little bit of foam strip not going to make any difference to you in a front collision over one mph.
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #57 on: April 03, 2017, 08:20:15 PM »
Hello, yes and no. There are tabs on the back of our trim rings to hold the grille in while also at the bottom a angle bonded to the underneath of the grill goes up against the inside of the bumper. 2 screws go underneath the top of the trim ring, not into the bumper but just past it to keep the trim ring in place. The only two screws are underneath the top and cannot be seen. No glueing or mess so it can be changed back for whatever reason.
« Reply #58 on: April 04, 2017, 11:21:07 AM »
ChopTop;1970953]For anyone who'd like to pick up an additional OEM energy absorber bumper.  Also might want to check w/Hoosier GXP for one.
ABSORBER. GXP Bumper/Fascia Energy Absorber Part Number: 25971689 ; 25777840 $122.12 (I have no idea why there are two part numbers.)
ABSORBER. Bumper/Fascia Energy Absorber for 2008 Pontiac Solstice GXP TURBO. #25971689
Base;
ABSORBER. Bumper/Fascia Energy Absorber Part Number: 15920757 ; 15799942  $122.12
ABSORBER. Bumper/Fascia Energy Absorber. BUMPER/FRONT for 2008 Pontiac Solstice Base. #15920757
« Last Edit: April 04, 2017, 11:38:36 AM by ChopTop »
« Reply #59 on: April 04, 2017, 11:36:18 AM »
I cut my foam support away in 2009 to make room for the first recessed grills and have never had any ill effects. Chopping it back a bit in two spots is something I would do again without hesitation.
« Reply #60 on: April 07, 2017, 10:07:14 AM »
Bought a set of brand new GXP Grills from Crate Engine. Tall Craig could not find his to sell to me. They arrive at Norm's today. He will then make me set of recessed grills. He will also paint the frames. He will bring them to Lexington Nationals and install them.  :tool: :yay: I think this should look pretty cool on my Black Coupe. Here is a pic of the Coupe pre white OEM stripe and the roadster with Race Mesh grills.
« Last Edit: April 07, 2017, 10:41:38 AM by Sly Bob »
« Reply #61 on: April 07, 2017, 10:09:27 AM »
Can anyone make the picture right side up? :banghead:
« Reply #62 on: April 07, 2017, 10:20:28 AM »
Pic looks good to me!
« Reply #63 on: April 07, 2017, 10:23:28 AM »
I've had that happen to me before Gareth. On the iPhone if you took the pic with the lens on the bottom when it's posted here your pic will be upside down.
They all do that and it's only the preview that's upside down.
EDIT: I fixed it by opening it in a photo editing program and re-saving the pic as a different name before uploading it to the KP server. Should look better now Gareth.
« Last Edit: April 07, 2017, 10:45:39 AM by Sly Bob »
« Reply #64 on: April 07, 2017, 11:30:40 AM »
Thanks Bob. :yay:
Offline marc4sgr
« Reply #65 on: April 10, 2017, 06:54:59 PM »
So awesome to see this happening.. I'm in for a set of GXPs!
« Reply #66 on: May 03, 2017, 07:31:46 AM »
Anyone got a set yet? Would love to see some pics. As I said earlier I get mine at the Nationals.
« Reply #67 on: May 04, 2017, 01:53:38 PM »
I've checked Norms Facebook page a couple of times, and other than the original post about it haven't seen anything announced.  But if it's like the rest of his products it might be one of those built to order type situations.
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #68 on: May 04, 2017, 10:07:19 PM »
Hello, knowing what I know now I should have made the GXP recessed grilles first. I cant believe how the openings are so different from the NA. The grilles are the same, not the openings with the curvature and overall shape off not by much but enough that you cant interchange. PIA got the GXP patterns almost done.
« Reply #69 on: May 05, 2017, 10:17:25 AM »
Hi Norm,
Keep us posted and pics if possible. Thank you for making these.
Gareth
« Reply #70 on: May 05, 2017, 04:00:44 PM »
Yes pics please so we can put them up on the site.
« Reply #71 on: May 05, 2017, 04:14:17 PM »
I still need to send him my grilles, or my spare set (which I haven't even had a chance to look for yet).
Offline normsf
  • Norms Fiberglass
    • Norms Fiberglass
« Reply #72 on: June 06, 2017, 10:48:49 PM »
Hello the Recessed grilles are now done for both the NA and GXP. The GXP has a slightly different curvature but the grilles themselves are the same except for color. Pictured is a NA bumper with our lower spoiler and added splitter which is painted in Carbon Flash as are the grille and grille frames. Price for NA or GXP grille frames are $295.00 ready to paint plus shipping. You reuse your stock Hex grille in back. Thanks again Norm 574-255-7843
« Reply #73 on: June 07, 2017, 01:35:53 PM »
Solstices get all the love... :(
« Reply #74 on: June 07, 2017, 01:56:04 PM »
Norm doesn't discriminate, write him a big check and he will love the Skys too!
