« Reply #3 on: March 05, 2010, 01:54:59 AM »
PureXTC-----> there are a lot of the forum Members that have the same problem. OK the best I can explain is- #1 get two peices of 2x8 lumber about 12inches long.-#2 place in front of your front wheels-#3 Drive the car on the 2x8's.-#4 Jack up the front and place your Jack stands .#5 Move your jack to the rear jack it up and place the jack stands where you need them Remember when you Put it down place the Lumber under front wheels Before lowering Jack in front
I hope this helps .
Anothher way is Drive the front up on Rhino Ramps then Jack up and place stands.In thr rear Jack up and Place Stands.If car is low use 2x8's to in front of Ramps
Logged
