Author Topic: New BC Racing ER Series (External Reservoir) Coilover Kit for the Solstice/SKY!!  (Read 2752 times)
BC Solstice/SKY/OPEL GT/Daewoo G2X ER Coilovers
The ER Series features large external reservoirs front and rear, independently adjustable rebound and compression, plus a mono-tube twin-piston design. The large external reservoirs allow for a higher oil capacity that translates to faster heat dissipation during extended road course use. Additionally, the external reservoirs house the secondary piston, which allows for the independent adjustment of compression, separate from rebound adjustment. The ER Series coilover is the perfect system for the driver who wants to dial in his or her suspension by varying the compression and rebound settings to fit a specific driving style and performance demand.
MONO-TUBE DAMPER WITH TWIN PISTON DESIGN
HEIGHT ADJUSTMENT VIA SHOCK BODY, NOT SPRING
30-CLICKS OF DAMPING ADJUSTMENT (COMPRESSION/REBOUND) SIMULTANEOUSLY
7 KG FRONT AND REAR SPRINGS
CUSTOM VALVED TO MATCH THE DRIVERS REQUESTED SPRING RATES
SWIFT SPRING UPGRADE AVAILABLE ON MOST APPLICATIONS
1 YEAR LIMITED WARRANTY AGAINST MANUFACTURER DEFECT
FULLY REBUILDABLE WITH ALL PARTS AVAILABLE FOR PURCHASE
Optional Swift lightweight racing springs available
2-3 week lead time - $2150.00
Available to order now here - http://www.performanceautowerks.com/catalog/product_info.php/solsticeskyopel-gtdaewoo-g2x-coilovers-p-2150
