Author Topic: Diagnostic help needed - P0446  (Read 3904 times)
Offline Rogue
« on: September 26, 2019, 08:17:02 AM »
I'm trying to help a friend with a 2004 Saturn Vue 3.5 engine. Code P0446 won't go away. I found a stuck purge valve and replaced it, still kept setting the code. The gas cap was in sad shape and wouldn't seal properly, replaced it. Still setting the code. I'm now planning on checking the charcoal canister andd valve, but it seems I've always found that to set a different code (P0449). Does anyone know where I should be looking next?
Go N.A.K.3.D..
Re: Diagnostic help needed - P0446
« Reply #1 on: September 26, 2019, 12:02:32 PM »
Trace the hoses and inspect the hose ends/nipples.
Looks like there are a few posts about this code on saturnfans.com after googling "p0446 saturn vue"
Offline Rogue
« Reply #2 on: September 27, 2019, 08:13:23 AM »
A good suggestion. Thanks.
Go N.A.K.3.D..
« Reply #3 on: October 02, 2019, 09:15:26 AM »
Would any of this help at all?
https://repairpal.com/obd-ii-code-p0446
Offline Rogue
« Reply #4 on: October 06, 2019, 04:42:30 PM »
Good info there. Thanks. It describes the process better than most of the other articles I've read. A pity I don't have a Tech II or equivalent.
Go N.A.K.3.D..
