Author Topic: ESC  (Read 4625 times)
Offline RLM68
ESC
« on: July 05, 2021, 09:35:55 PM »
My ?ESC OFF? keeps popping up and traction control, any ideas
Re: ESC
« Reply #1 on: July 07, 2021, 11:00:32 PM »
Is there anything else happening with the car?
Chances are you are going to need a scanner hooked up and see what codes are set.
Re: ESC
« Reply #2 on: July 08, 2021, 06:11:01 AM »
Did you have any work done recently on your wheels/wheel bearings/brakes?  I'll get that after tire slippage(burn out :lol: ) or dyno
Re: ESC
« Reply #3 on: July 08, 2021, 07:13:35 AM »
Hows you're battery? On both my Kappa (when I had it) and my Camaro I'll get ESC/stability control issues if I start it with a low battery.
Re: ESC
« Reply #4 on: July 08, 2021, 11:03:19 AM »
This is what I had too, I also had it when the ECM was being overworked because of a cam issue (not on the Kappa but another Pontiac).
Re: ESC
« Reply #5 on: July 08, 2021, 01:29:57 PM »
Check the ABS/rotation sensors & wiring at each wheel (also, while you're there, check the hub bolts are all tight - 3 bolts/wheel hub).  A faulty sensor or busted wiring can play havoc.
