Author Topic: Clearance problem with 275/40/18 tyres  (Read 11832 times)
Offline iliasGT
  • Back in Black
« on: June 10, 2023, 11:16:09 AM »
Will i have clearance issues using 275/40/18 tyres on 9x18 wheels (40 offset) square setup?
Weitec Hicon GT coilovers,DDMWorks probeam,DDMWorks Backbone,DDMWorks oil catch can,LV Kappa Front Chassis Brace,Z0K rear sway bar,DDMWorks Stainless Steel Brake Lines,Norms diffuser,DDMWorks cupholder, konigseder rear wing,stubby antenna,custom rear and horn logo,front and rear eyelids,steinmetz front grill,isotta e-brake, Stainless steel door pins,Custom stainless steel door sills,Custom front sway bushings,Custom oil carter protection.
Re: Clearance problem with 275/40/18 tyres
« Reply #1 on: June 12, 2023, 02:01:01 PM »
Here's a great site that will tell you where you'll need the clearances for a non-stock tire. At a quick glance, I would think you will be alright but run the numbers in that site and you'll know for sure.
https://www.willtheyfit.com
