Author Topic: Rear Diff and Manual Oil Change and clutch replacement.  (Read 5883 times)
« on: March 23, 2009, 08:22:09 PM »
Start by dropping the exhaust.  Since this was a Solo RCD, we just had to remove the middle and front half.
When draining the rear diff or the manual transmission, always remove the fill plug first.  If you strip it out, you won't be stuck with no fluid.  Tips from Randy @ DDM
Rear Differential
Filled with RP
Remove the BackBone and trans cover.  Draining the manual trans.  We need it lighter to remove it.
Support the transmission and remove the transmission support bracket.
Next - remove the drive shaft.
Rear diff with shaft out.
Remove all the bolts from around the transmission.  The one above the starter required a 17mm Deep on a universal and a 3" extension.  All tapped together so you don't have to keep fishing them out.  Remove the clutch hydraulic line and the neutral safety switch harness. Then lower the transmission
Re: Rear Diff and Manual Oil Change and clutch replacement.
« Reply #1 on: March 23, 2009, 08:22:25 PM »
Transmission is out...
QA inspection of clutch slave cylinder, we refilled with RP while on the stand...
Old Clutch assy
Cleaned up
Mop Boy
Old Clutch
New Clutch
Installed
Reverse the rest and bleed the clutch with a VACUUM type bleed system.
« Last Edit: March 23, 2009, 08:27:43 PM by DeepBlueGXP »
Offline GTO3296
  • I'm growing older, but refuse to grow up!
« Reply #2 on: March 23, 2009, 09:44:20 PM »
Just wondering... How many miles did you get out of the original clutch? Thanks....
07 GXP, Aggressive, manual, sport pedals, top liner, leather w/red stitching, XM/6 disc Monsoon, AC, Spoiler, Color Keyed Splash Guards, windrestricter, open exhaust (local shop), BOV spring, slotted/dimpled rotors & painted calipers, DDM Backbone
Other vehs - 66 GTO, 98 Firebird Formula (many mods), 08 GMC Sierra Denali, 01 Harley Ultra (Screaming Eagle mods).
« Reply #3 on: March 23, 2009, 10:36:41 PM »
1) Is this a GXP?
2) Does it have the torque arm?
3) How many hours did it take?
« Reply #4 on: March 24, 2009, 12:17:24 AM »
1) Is this a GXP?
I believe that this is Critterman's car so no its not a GXP and so it would not have the torque arm.
It kind of looks like the diaphragm fingers on the old pressure plate are a bit out of whack, was he having problems with the clutch or was this just an upgrade?
Offline chuckdoc
« Reply #5 on: March 24, 2009, 07:11:54 AM »
His car is supercharged and he had increased the HP (work by DDM) so much he felt a better clutch would be a good idea.
My KappaPerformance Mod Page
« Reply #6 on: March 24, 2009, 09:25:50 AM »
The clutch wasn't worn out but was quite weak due the springs mentioned above.  The job took about 5 hours total, mainly because one bolt is very difficult to get to.
« Reply #7 on: March 24, 2009, 01:42:47 PM »
1) Is this a GXP?
A couple people pointed it out already, but his a 2.4L with a supercharger on it without the torque arm. There are a couple ways to spot it for future reference also. The 2.4L has the flywheel held to the crank with 6 bolts and the 2.0L has it held to the crank with 8 bolts. That should help in the future also just incase someone doesn't know what they have, 6 bolts 2.4L, 8 bolts 2.0L.
Hope that helps!
Dave
« Reply #8 on: March 24, 2009, 09:42:28 PM »
The SOB's forgot to tell you about the joke they played on me draining the rear.  It seems they had some metal shavings in their drain pan so a quick dip of the magnetic drain plug into the the oil and shavings residue resulted in metal chips on my drain plug.
Randy walks over to where I am with the plug and shavings with this long face saying, Critter this doesn't look good..........
Clutch was fine, it has a 3 gaps between the fingers on the pressure plate, why I don't know, but the clutch itself was fine, had lots of life left in it if I was running less horse power.   With this set up I need a lot stiffer clutch.   About 32k on the clutch that came out.
