I would certainly get DDM's KWs if I could afford the nearly $2k it would cost. But I do not feel right picking Dave's brain when considering someone else's product
I definitely prefer to buy from our vendors here whenever possible.
But the BC BRs I am looking at are at a price point almost half of the KWs offered by DDM. The BCs are quite popular and well reviewed on other platforms, and a couple of BB folks have them installed on Kappas. They seem like an option at least worth considering.
I was confused by the "7k" rate I was given, too. I think it may be metric -- 7kg per mm of travel??
I understand our stock suspensions come with coil springs over Bilstein shocks, but what I meant by coilovers was the adjustable perch, spherical bearing top, type. Interesting that the Kappa has lower rate fronts. As Snapon confirms, usually we see stiffer fronts on a RWD sports car. I may be on to something after all . . . Snapon, I will PM you. I understand you brewed up some coilovers by revalving Koni Sports, and selecting appropriate springs.
Alignment is another story. Re-alignment, and also corner weighting, I consider absolutely necessary if I switch the shocks and springs and drop the ride height the inch or so it needs now. Most places quote a flat rate for a four wheel alignment (about $100+/- locally) and 2-3 shop hours for corner weighting.
That adds a couple hundred more $$$ to the switch, which also has to be factored in to the budget impact.
