Author Topic: Drag race results - 4/19/09 - my first time  (Read 6129 times)
Offline Excelsior
« on: April 20, 2009, 01:16:09 AM »
The track was a bit slippery as all the other drivers were saying.  One guy knows he runs in the 11s but was 13+ all day due to the track conditions.
I ran from 10am - 5pm at the track.
Weather from reported weather for the day.
50 - 66 degrees
69% - 33% humidity
Mach Shorty
Wester's RACE Tune
Driver weight 290
I started with 5/8 tank of 93 octane gas and this is completely different than autocross.  It requires a whole new train of thought.  I really think that the turbo killed me a little with wheel spin especially since you cannot hear it.
6 runs
1) 11:16am (Competition mode)
Reaction ---- .7399
60 ft ------- 2.2803
ET @ 594 FT - 8.7860
1/8 ET ------ 9.3721
1/8 MPH ----- 76.78
1/4 ET ------ 14.4450
1/4 MPH ----- 96.80
2) 12:04pm (forgot to change computer mode and screwed up shift into second because that is when it dawned on me)
Reaction ---- .6269
60 ft ------- 2.7000
ET @ 594 FT - 9.9331
1/8 ET ------ 10.5280
1/8 MPH ----- 75.64
1/4 ET ------ 15.7419
1/4 MPH ----- 95.78
3) 12:50pm (ground 2nd just a touch)
Reaction ---- .7569
60 ft ------- 2.4731
ET @ 594 FT - 9.1580
1/8 ET ------ 9.7261
1/8 MPH ----- 79.20
1/4 ET ------ 14.7972
1/4 MPH ----- 96.31
4) 2:44pm
Reaction ---- .7219
60 ft ------- 2.2121
ET @ 594 FT - 9.1901
1/8 ET ------ 9.7862
1/8 MPH ----- 75.48
1/4 ET ------ 14.9073
1/4 MPH ----- 96.28
5) 3:38m
Reaction ---- .8760
60 ft ------- 2.2369
ET @ 594 FT - 8.7699
1/8 ET ------ 9.3600
1/8 MPH ----- 76.25
1/4 ET ------ 14.4520
1/4 MPH ----- 96.54
6) 4:30pm
Reaction ---- .6410
60 ft ------- 2.4480
ET @ 594 FT - 9.2420
1/8 ET ------ 9.8450
1/8 MPH ----- 74.61
1/4 ET ------ 15.0271
1/4 MPH ----- 95.72
09 Corvette run
Reaction ---- .6899
60 ft ------- 2.3161
ET @ 594 FT - 8.1471
1/8 ET ------ 8.6501
1/8 MPH ----- 89.46
1/4 ET ------ 12.9730
1/4 MPH ----- 114.25
Let me know how I did please.
Offline Excelsior
Re: Drag race results - 4/19/09 - my first time
« Reply #1 on: April 20, 2009, 01:18:28 AM »
video tomorrow sometime when I get to it.
Offline PubliusE
« Reply #2 on: April 20, 2009, 01:21:09 AM »
What Track were you on Lebanon Valley?
Offline Excelsior
« Reply #3 on: April 20, 2009, 02:54:27 AM »
ESTA in Cicero, NY
« Reply #4 on: April 20, 2009, 06:33:15 AM »
Did you deflate your tires to 19 psi for the track?  Times seem high but you did say that the track wasn't that good.  You can see on your second run that TC slowed you down on you on the 60ft time
« Reply #5 on: April 20, 2009, 09:16:10 AM »
Last on threw me, until I saw the heading on it, I was going to ask if you used a different car.
It's all about getting out of the hole and theire are verious was to do that, I'm not very good and it takes a lot of practice.  The best time I have seen from a GXP was Rusty at Cecil county and he turned a 13.85, but he does work there and I think knows all the tricks.
Joe's best time that same day was a 14.01, mine with a stage I supercharger was 14.102.
Tire pressure around 20 lbs,  you should be able to launch around 2-2.5k.  Some slip the clutch others dump it.   Not sure which way is best, with my stage III, I have been launching at an idle using both clutch technics and just burn the tires off in 1st and 2nd.
Offline HotScott
« Reply #6 on: April 20, 2009, 10:22:11 AM »
I ran 13.54 and 13.49 at Capitol Raceway last year, same setup, Westers Tune.  So sounds to me the track conditions came into play.  Also my car is stock except for the tune.  My brother in laws automatic solstice ran 13.6 that same day.  I would say try again when conditions are better.
•Werks Tune
  •Performance Werks V8 525hp Conversion
  •T-56 6 Speed Manual
  •Spec 2+ Clutch
  •Custom Stainless Dual Exhaust
  •BC Racing Coilovers
  •Rear Brace
  • A/C and Cruise
  •Forgestar F14 wheels and Pilot Sport tires
Offline PubliusE
« Reply #7 on: April 20, 2009, 01:22:42 PM »
ESTA in Cicero, NY
Oh.  I was thinking about giving a run at Lebanon Valley one night this summer.  Never ran on the track before so I think it will be fun.  Also, are you running the GMPP Tune?  Wondering if you used the No Lift Shift Function and what you thought of it on the track.  I am so programed to lift and shift I can't seem to do it without trying too hard.
« Reply #8 on: April 20, 2009, 01:25:18 PM »
Did they warn you about the 13.49 and no roll bar?
« Reply #9 on: April 20, 2009, 02:59:45 PM »
He need to get his tire pressure to about 20 to get as much byte as he can from street tires.
Offline holeshot134
« Reply #10 on: April 20, 2009, 07:57:24 PM »
I'm hotscott's brother-in-law.  Ran a 13.6 but no they didn't warn about not having a role bar.  Just told us to keep the tops up and we were required to wear a helmet.
Offline baconbits
« Reply #11 on: April 20, 2009, 08:21:38 PM »
Funny how you need a roll cage in a 13 second car but they'll let pretty much anyone run a low 10 on a street bike..
From NHRA
When do I need a roll bar or roll cage, and what should it look like?
A roll bar is required in any convertible running 13.49 seconds or quicker in the quarter mile, and in other cars beginning at 11.49. The roll bar is accepted in vehicles running as quick as 10.00 second e.t., provided the stock firewall and floorboard is intact, other than for installation of wheel tubs. The rollbar must be constructed of minimum 1 ¾ inch o.d. x .118 inch wall mild steel tubing, or 1 ¾ x .083 chrome moly tubing, and must conform to the following diagram:
Sorry didn't post the diagram.. but the cage cannot be four point in construction...
http://www.nhra.org/contacts/tech_faq.html ..
Bacon
Offline Excelsior
« Reply #12 on: April 21, 2009, 01:49:41 AM »
I was told I had NLS, but as hard as I try, the tach skyrockets to the top end.  I might have to make a call.
Offline HotScott
« Reply #13 on: April 21, 2009, 12:52:17 PM »
Well that was the last run I made while I was there, so no one said anything.  I even rented a helmet from them.  And I suck at drag racing, so anyone that is better, I am sure would get a time lower then mine with the tune etc.  Be curious to see what Joes car would run with the mods he has.
•Werks Tune
  •Spec 2+ Clutch
  •Rear Brace
  • A/C and Cruise
Offline Excelsior
« Reply #14 on: April 21, 2009, 01:31:15 PM »
VIDS!!!!!!!!!!!
http://www.ddz.net/solstice/esta
I have to remember to get a better camera if I do this again.
In 5689 you can hear a little kid saying "go black, go black, go black".  LOL.
