Author Topic: Tuning 101  (Read 32267 times)
Offline Koobie
Tuning 101
« on: May 17, 2009, 10:22:17 PM »
If you want to sticky this, go ahead, but I think with so much talk about our cars and the "tune" being the key mod, we should have some explanation on what consists of tuning!!
Tuning 101 (primarily N/A discussion):- "SEE POST 13" of this thread
Feel free to let me know of some me pages and I will add them! :)
« Last Edit: November 28, 2022, 07:12:59 AM by DeepBlueGXP »
2001 BMW 330Ci
2007 Sky Red Line
Both paid for...woot! :)
Re: Tuning 101
« Reply #1 on: May 17, 2009, 10:43:32 PM »
Go ahead and copy all 5 pages and paste here.  Leave the reference link for credit.  That way if their site happens to be down, users will still be able to read about it.
Re: Tuning 101
« Reply #2 on: May 18, 2009, 06:37:12 AM »
Very good article.
1000 posts now it's official I'm a gearhead
« Last Edit: May 18, 2009, 07:02:16 AM by lil goat »
Offline Koobie
Re: Tuning 101
« Reply #3 on: May 18, 2009, 11:07:16 AM »
Cool.  I'll update it tonight, as the work filter is telling me I can't go to Importtuner.com due to lingere & swim wear LOL.
2001 BMW 330Ci
2007 Sky Red Line
Re: Tuning 101
« Reply #4 on: May 18, 2009, 11:39:12 AM »
Very good article.
So all I gotta do is post about 800 more times and I'll be a gearhead?  Score!
Re: Tuning 101
« Reply #5 on: May 18, 2009, 12:55:24 PM »
Hey at least you don't have a junior member.
Re: Tuning 101
« Reply #6 on: March 20, 2017, 12:40:41 PM »
Here is an excellent video series called Tuning 101, it uses both the E67 and E78 ECUs as examples along with HP Tuners.
https://www.youtube.com/watch?v=u1wzEVwAfJQ
Offline Bgobrecht
Re: Tuning 101
« Reply #7 on: September 26, 2021, 05:37:06 PM »
Site no longer works.
Re: Tuning 101
« Reply #8 on: September 26, 2021, 10:23:20 PM »
The link to the video above?
Re: Tuning 101
« Reply #9 on: September 26, 2021, 11:47:35 PM »
Works for me.
Re: Tuning 101
« Reply #10 on: September 27, 2021, 06:43:50 AM »
When I click watch on youtube, it works
Re: Tuning 101
« Reply #11 on: September 27, 2021, 06:46:05 AM »
Oh, he's referring to the link in the first post.  It's an invalid URL
Re: Tuning 101
« Reply #12 on: September 27, 2021, 08:05:21 AM »
Yeah, if that's the case he's likely out of luck as it looks as though the entire importuner.com site has disappeared.
Offline agent008
Re: Tuning 101
« Reply #13 on: October 01, 2021, 02:12:12 PM »
Here's a copy and paste from the original link as recorded by the Wayback Machine (web archive) on Nov 14 2012:
Tune Into This - Engine Tuning 101
AFR, MAP, IAT... Confused? Not Anymore
Import Tuner, December, 2006
Engine Tuning Basics Lead
Good tuning is the key to unlocking the potential of any engine. OE manufacturers spend ungodly amounts of time, money and research fine-tuning engines to run as efficiently as possible at all times, under any conceivable operational conditions. Simply put, if your engine is stock, it's unlikely you can get a better overall tune than the one it came with. Make a few changes though and things can change rather quickly.
An internal combustion engine is basically like a big air pump. As it comes equipped from the factory, it will flow a set amount of air based on things like engine speed, load, etc and is tuned accordingly. When changes are made to the things that regulate the amount of air that gets into an engine (cams, header, intake, forced-induction, etc.), changes need to be made to the engine management to compensate. This entails adjusting fuel and/or ignition timing, at minimum if the engine's potential is to be realized.
Basically, when airflow is increased, fuel delivery must be increased accordingly. The goal is to get the fuel and the air into the engine in the correct ratios. But don't be fooled into thinking that tweaking the air/fuel ratio (AFR) is the only thing that needs to be addressed when making serious changes--it's not that simple.
Engine Tuning Basics Spark
Getting more air and fuel into the engine means that there is a bigger explosion happing, which means higher temps and pressures in the combustion chamber, which can dramatically increase the chance of detonation and engine damage. As such, ignition timing often must be adjusted as well.
While comprehensive tuning involves more than just tuning the fuel delivery and ignition timing, they are 90 percent of the equation. Also, if these two things are in order and set conservatively, chances of engine survival are good.
Just like everything in life, tuning is about compromises. The key to getting the best tune is to balance maximum power and engine safety, without running the car on the threshold of destruction. Twenty years ago, tuners relied primarily on their eyes, ears, noses and timeslips to tune, which required years of experience. Today, thanks to modern fuel injection systems, we have a mess of sensors under the hood, which makes things a lot easier.
- Check out the following pages for more engine tuning info!
Fuel Tuning
Engine Tuning Basics Blitz Rvit
One of the most important and basic engine tuning aspects is dialing in the AFR or air-fuel ratio. This is the proportion of fuel-to-air in the combustion chamber at the time of ignition. Even slight changes in the AFR can have a dramatic effect on power output, drivability and emissions. An AFR of 13:1 means that there is approximately 13 times more oxygen going into the engine than fuel; hence the "thirteen-to-one" ratio. For a given amount of fuel, you need a set amount of air to burn it completely. When the two are present in a ratio that burns both completely, it's called a stoichiometric mixture, or stoich (14.7:1). This is why a stoich mixture is considered "ideal" AFR for gasoline engines.
Unfortunately, 14.7:1 is no magical AFR that will net maximum power. Ideally, an engine should be tuned to have different AFRs under different engine loads and RPM.
Chances are, you've heard the terms "rich" and "lean" before, but do you really know what they mean? It's pretty simple, actually. A higher AFR is a lean mixture, a low AFR a rich mixture.
A rich mixture is one in which there is more fuel present than there is oxygen needed to completely burn the mixture. Slightly rich mixtures leave extra fuel in the chamber and can be good for cooling the intake charge and warding of detonation, but on the downside, rich mixtures can cost us horsepower, decrease mileage, increase harmful emissions, and leave carbon deposits on the valves and combustion chamber. In extremely rich mixtures, the excess fuel can even run past the cylinders and rings to contaminate the oil and possibly damage the cylinder walls and rings.
A lean AFR, on the other hand, is one in which there is more air present than needed to completely burn all the fuel, leaving extra oxygen in the charge. This increases the likelihood of all the fuel being burned and is why mileage increases and emissions are generally lower. On the downside, lean mixtures burn more slowly and at higher temps, which can cause burned valves, detonation and other problems, especially under high load conditions (wide-open throttle).
Tuning the fuel boils down to setting some targets for your AFRs and doing your best to hit those targets. For naturally-aspirated cars, AFR's should usually range from 14.7:1 at idle and very light throttle, 14:1 to 13:1 at part throttle, and around 12.5:1 at wide-open throttle.
The AFR targets for a forced-induction car are a little different. Normally, the off-boost targets will be the same as naturally aspirated engines, but under boost they usually are tuned to run rich, which leaves extra fuel in the chamber for cooling and reduces the chances of detonation. On crappy pump gas (91 octane), most tuners we know tune using conservative AFR targets under boost (around 11:1 to 12:1).
There are different methods for tuning fuel delivery, but all work in one of several ways: increasing the fuel pressure (which increases flow), increasing injector size, modifying the signal to the injector or adding injectors. The first is normally done via a rising-rate fuel pressure regulator, the second is obvious and the third is done electronically by magical boxes that cost a small fortune and the fourth is a no-brainer. We've listed them along with a few terms and parts that are essential to tuning fuel.
EFI FUEL TUNING STUFF
Fuel MAP
This is a grid with engine speed on one side and engine load on the other. The MAP or MAF sensor signal tells us engine load and, based on this and the engine speed, the ECU looks up the two coordinates on the fuel map and injects the correct amount of fuel. Programmable ECUs allow you to change these values and change the AFRs throughout the operating range on the engine.
Oxygen Sensor
This one's a biggie. This sensor is the device that tells us the AFR. Without it, you can't effectively tune. Mounted in the exhaust stream, it measures the amount of oxygen leaving the combustion chambers and is used by the computer to calculate the AFR. There are two types of O2 sensors: narrow and wideband. Unless you live in the third-world or you like inaccurate data and crappy tunes, get the wideband. It's faster and has a useable AFR range (10:1 to 20:10), while the narrowband works well only around stoich (14:1 to 15:1). If $200 is still too much for the cheapest of ya'll, there's always the DIY wideband O2.
Rising Rate Fuel Pressure Regulator
Used primarily with low-dollar and smog-legal forced induction kits, this device does nothing under manifold vacuum conditions, but once the engine sees boost, it increases the fuel pressure proportionally with boost pressure. The increased pressure at the fuel injectors means that more fuel gets into the engine. It only works with return-type fuel systems and since it does not change the signal to the injector, you can't fine-tune it.
Injector Signal Modifiers/Generators
For simplicity, we've grouped together all the electronic devices that change or replace the signal to the fuel injectors; including ECUs, AFCs, piggybacks, re-flashes, etc. What these devices do is control how much fuel is delivered to the engine. They typically have their own displays or link to a laptop computer to allow the user to add or subtract fuel according to the wideband in order to hit their AFR targets in all the different "zones" on the fuel map. The fancier ones have features that allow it to communicate with the oxygen sensor and self-tune the AFR for all the different engine loads and speed all by themselves--while you drive.
Extra Injector(s)
Just what it sounds like. Mounted somewhere in the intake tract (usually near the throttle body), the extra injectors are controlled by an extra computer. A downside to these units is that fuel can only be added, not subtracted from the base map.
MAP/MAF Sensor
Most fuel-injected cars have either one of these sensors. This is the signal that will tell you the engine load. Learning to interpret this signal is the key to getting a good tune. Depending on the load, you need to vary the AFR. The MAP (manifold-absolute-pressure) sensor is mounted on the intake manifold and tells the computer how much pressure or vacuum is in the manifold. Based on engine speed and load (MAP), the total airflow can be calculated. MAF (mass-air-flow) sensors measure airflow directly.
Engine Tuning Basics Hks Spark Plugs
Spark Tuning
Unfortunately for the backyard tuner, developing a good spark map isn't as straightforward as tuning the fuel with a wideband oxygen sensor. Ideally, a spark map should be developed on a chassis-loading dyno (Mustang). The car is run on the dyno and for every RPM and load bin (the spot on the spark map), the ignition timing is advanced until torque starts to drop off. The point right before the torque drops off is called MBT or mean best torque.
There are a couple of problems with this method. One is the cost of renting a dyno for hours on end. It could easily cost a fortune to get it nailed. But the biggest problem with this method is that many engines (especially high-compression and forced-induction) will encounter knock before reaching MBT. Most engines will ping before reaching MBT.
Engine Tuning Basics Spark Plugs
Because of this, we must keep an ear out for knock while tuning. While knock can be heard, it's much safer to rely on a knock sensor to serve this duty. It's safest to make only changes where needed to the spark map. Typically, the low-load ignition timing that the engine uses stock is best. It's really only under high load and with higher-compression pistons, etc. that other areas in the spark map might need to have some ignition advance removed.
When tuning ignition timing with a knock sensor, you simply reduce the timing advance under those conditions that you encounter knock. There are numerous to control ignition advance. We've listed a few ways and some other terms that will help you.
Engine Tuning Basics Spark Plug Wires
SPARK TUNING TERMS
IAT Sensor
The intake air temperature sensor tells us the how hot the air is as it enters the engine. The higher the temp, the higher the chances of knock. If intake temps can be lowered, more ignition-timing advance can be added, which adds power (unless you've hit MBT, which is unlikely under a high load). This ability to add advance when temps are lowered are part of the reason why cold-air intakes and intercoolers can add power.
Detonation
Detonation, or knock, is when the air/fuel mixture ignites before the cylinder reaches maximum pressure. The result is a supersonic and out of control explosion in the chamber that puts stress on the engine that it wasn't designed for. Low-octane fuel, high compression ratios, advanced ignition timing, high intake temps, and a number of other things can cause detonation. Detonation breaks pistons and bends rods.
Preignition
This is when the mixture ignites before the spark plug fires. It is caused when isolated spots in the combustion chamber glow red-hot and ignite the mixture before it's supposed to. These hotspots can be caused by carbon build up, poor design, or other factors. Preignition isn't the same as detonation or knock. Anyone who's been in a junker that keeps running after it's been shut off knows what preignition is.
Electronic Timing Controllers
This is the way to go. On the low end of the scale are devices that simply retard the timing according to load. On the high end, we have the programmable ECUs that, just like tuning the fuel, allow us to make changes at any point of the map we encounter knock, leaving the rest alone. With the lower end types, you may have to retard the timing for the whole RPM map, even though it may only knock at 4500 RPM.
Base Timing Adjustment
This is the ghetto way to adjust the timing. This is usually done when an owner makes mods but doesn't realize that they need ignition mods until they hear that ugly metallic ping of detonation. While this may ward off knock the 10 percent of the time the cars at full throttle, the other 90 percent of the time it'll be a sluggish piece of crap. Many low-end and backyard turbo "kits" utilize this to avoid detonation under boost. People that add high-compression pistons and have no form of spark control often resort to this level of barbarianism, too.
Knock Sensor
A knock sensor is a device that measures engine noise and sends a signal to the computer when there is detonation. Most sensors have some "background" noise in their signals, but real knock events are easily distinguished because they are so violent and register big values when it happens.
Offline phantomjock
Re: Tuning 101
« Reply #14 on: September 04, 2022, 02:51:11 PM »
Thanks for saving it here.  The Wayback is not showing this document - at least I didn't find it.  Much appreciated.
Cheers - Jim
Speed is Life!  I feel the need...
