Author Topic: Frontal area and CdA of various vehicles and how they stack up?  (Read 9717 times)
I hope you all will forgive me for re-posting this but...I am kind of a sentamental and emotional type of guy and this was one of my firsts post, a long time ago on a different forum.  So, just for the heck of it let's go back in time.  Here is the post again.  If you want to make a comment go ahead.  You see GM tested the heck out of this vehicle before finally bringing it to market.  Many of the tests were in jolly old England and cavorting in the fray were MG's and other English Sports Cars of the era.  Well, here goes...
I've known the frontal area and CdA since my original Post.  The frontal area is 21.1 ft.  That's almost the same as the much bigger Corvette. The Solstice CdA 9.5.
For comparison purposes, here are some CdA's followed by the pounds of force exerted on the car @ 70 and 150 mph.  (Assuming each car could hit 150mph):
Nissan 350Z:    5.8  CdA,  77 pounds @ 70mph, 353 pounds @ 150 MPH
C6 Corvette:    6.16 CdA,  82 pounds @ 70mph, 375 pounds @ 150 MPH
Porsche 911:    6.8  CdA,  90 pounds @ 70mph, 413 pounds @  150 MPH
Dodge Viper:    7.7  CdA, 102 pounds @ 70mph, 468 pounds @  150 MPH
Scion XB:        7.7  CdA, 102 pounds @ 70mph, 468 pounds @  150 MPH
Miata:            8.01 Cda, 106 pounds @ 70mph, 487 pounds @  150 MPH
Honda 5200:    9.08 Cda, 120 pounds @ 70mph, 552 pounds @  150 MPH
Solstice:         9.5   Cda, 126 pounds @ 70mph, 578 pounds @  142 MPH
New Beattle    9.6   Cda,  127 pounds @ 70mph, 584 pounds @  150 MPH
Chrysler T&C
Minivan:         10.9 Cda,  144 pounds @ 70mph, 663 pounds @ 150 MPH
Cadillac Esc.  12.89 Cda,  171 pounds @ 70mph, 784 pouinds @ 150 MPH
The Solstice is running about 5050 RPM in fith gear at it's top speed of 142 mph.  At that speed, there is 518 pounds of force pushing back against the car due to wind resistance.  Factoring in the drivetrain loss, gear ratio, axle ratio, and tire size, that's about how much force the engine can deliver to the gound at that speed, so that explains the top speed on hte car.  If the car had a drag coefficient of .35 (which  is still kinda poor by todays standards) instead of .45, I calculate it could hit about 160 MPH.
« Last Edit: May 21, 2009, 03:08:57 PM by GXPinKC »
Offline SolNut
Re: Frontal area and CdA of various vehicles and how they stack up?
« Reply #1 on: May 21, 2009, 12:56:25 PM »
Got any info on da Coupe?
Steve
« Reply #2 on: May 21, 2009, 12:59:48 PM »
So what your saying is our pretty little car has about the same wind tunnel profile as say A BRICK! and why I want one of these, not sure it will help at all but I still want one.
« Reply #3 on: May 21, 2009, 01:01:50 PM »
It didn't link, but I'm guessing it is the front end on the Werks Performance site.  White won't look good on the front of your car.
« Reply #4 on: May 21, 2009, 01:31:25 PM »
Anyone know the numbers on a Sky?
And FWIW, drag isn't a big deal on a sports car. If you've got an econobox, fuel efficiancy is you biggest concern, hence why Civics, Priuses, and the like are extremely aerodynamic. Less drag means better gas mileage.
With sports cars, fuel efficiancy is not the big concern, performance is. A real spoiler will help with high-speed cornering, but it increases the car's drag. Sports cars are also designed to look good, so a design that isn't that aerodynamic is acceptable.
And then, you've got lift to deal with. At high speed an '07 Civic like I used to own would take off like a plane. (well, probably more like Carl Edwards at Talladega...) Obviously the Civic isn't designed for high-speed applications, and this sort of thing isn't acceptable in a car designed for high speed use. And yes, get it going fast enough and a Kappa would do the same thing.
« Reply #5 on: May 21, 2009, 01:33:26 PM »
Link shows up for me, it the RK sport front end they don't make anymore. I have really liked it from day I and came close to doing it to my NA way back when. I found one at a good price but got the coilovers first, damn you Dave!
Offline madmods
« Reply #6 on: May 21, 2009, 03:25:11 PM »
[/quote]
Heres a little trivia knowledge, and sorry to hijack the thread. This actual front end was used to make Norms f430 front end. The rk prototype was made out of fiberglass. That hood once graced my car, but it was fake. The air outlets did not work. It was sent back to Rk and they sold it on ebay as a non functional hood.
« Reply #7 on: May 21, 2009, 03:53:10 PM »
I like the front end as well, but it is definately a shovel.  You would have to have a street sweeper running in front of you.
Ben L
« Reply #8 on: May 21, 2009, 04:41:21 PM »
It won't stay that pretty long on the street.
« Reply #9 on: May 21, 2009, 05:09:37 PM »
Ok, I give up.  The shovel comes out on top.  I remember way back, Motor Trend, in the October 2006 issue had a ten page article and in it they evaluated the 2007 Pontiac Solstice GXP, the BMW Z4 3.0si, and the Nissan 350Z Roadsters.  Well, the Solstice GXP beat the Nissan 350Z in every acceleration category.  The GXP was only mila-seconds in back of the BMWZ4 3.0si.  All of this, and the 2007 Solstice GXP was awarded 1st place in the final tabulation.  And after all this, it had a CdA rating worse than the other two.   :woohoo:
Anyone have and explanation for how it could do so well in the performance peramiters, and yet have the worst CdA and wind resistance factor of any of the cars participating in this review?
« Last Edit: May 21, 2009, 05:51:19 PM by GXPinKC »
Ben L
« Reply #10 on: May 21, 2009, 05:16:48 PM »
More grunt?
Offline HAMMER DOWN
« Reply #11 on: May 21, 2009, 05:41:46 PM »
 :agree: if I remember right the sol had the best hp to weigh ratio. CdA is not has important as hp\tq.  :drag: :brnout: :D
« Reply #12 on: May 22, 2009, 08:57:44 PM »
Perhaps there are errors in how the CdA was calculated between the various makes?
Offline JRinKY
« Reply #13 on: May 24, 2009, 11:01:54 AM »
GXPinKC : ..... Anyone have and explanation for how it could do so well in the performance peramiters, and yet have the worst CdA and wind resistance factor of any of the cars participating in this review?
Mainly power (or torque) to weight ratio. The Solstice GXP has more or equal hp/lb and more torque/lb than either of the other two.
Also, aerodynamic drag does not become a significant factor until 30 or 40 MPH.
Offline JRinKY
« Reply #14 on: May 24, 2009, 11:20:55 AM »
Uranium-238: Anyone know the numbers on a Sky?
The Sky is very slightly more aerodynamic, with a CdA of 9.4xx, which results in a top speed that is 1-2 MPH higher. Not enough difference to really matter.
Not exactly correct. Drag is always a big deal, although it may not be the highest priority, and you are correct that it is frequently compromised by styling, cost, and other concerns.
You are confusing the operation of a spoiler with that of a wing. They are quite different things.
A wing behaves as you said: It generates downforce at the expense of added drag.
A spoiler, on the other hand, does just what its name implies: It spoils the smooth flow of air across the body. The smooth flow of air across the top of the car's body is one of the things that causes lift, and by generating the right kind of turbulence in the right place that lift is reduced. Also, when that smooth flow of air reaches the back of the body it can generate a very turbulent wake, which results in drag. Again, by generating the right kind and amount of turbulence in the right place, the size of the wake can be reduced, thus reducing drag. It is even possible to do both.
The spoilers fitted to the Kappas are basically decorative because the airflow at the tail of the car is already so turbulent that not much can be done with it. They do start to have some effect over 100MPH, but GM has indicated that even then it is not significant.
« Reply #15 on: May 24, 2009, 12:12:11 PM »
Yes, I did have spoilers and wings confused...I thought the names were interchangeable, but was wrong. Thanks for the explanation.
Can't spoilers produce downforce as well though?
Offline JRinKY
« Reply #16 on: May 24, 2009, 06:19:09 PM »
Uranium-238: Yes, I did have spoilers and wings confused...I thought the names were interchangeable, but was wrong. Thanks for the explanation.
No, a spoiler cannot produce downforce, but what it does results in more or less the same thing, at least up to a point. As you stated earlier, all car bodies generate lift. A spoiler can reduce the lift that the body generates, and reduced lift is equivalent to added downforce. Of course, it cannot reduce lift completely so at some point the spoiler has to give way to the wing if more downforce is required.
« Reply #17 on: May 24, 2009, 07:06:12 PM »
Better power curve and or better power to weight ratio.
More than likely the Sol has a better power curve than the other two vehicles you mentioned and or better power to weight ratio.
If you look at 2 TQ graphs on the same type of vehicle with same mods and one of the TQ graphs is flatter than the other but both have the same max Tq.  The vehicle with the flatter TQ curve  if everything else is the same will be quicker.  I can also workout that even though the flatter TQ curve might have a lesser max TQ it may still be quicker than the the curve that has the higher max TQ.  TQ gives you the grunt you feel when you take off and gets you from point A to point B quicker.  While HP will help you out at the top end and get you going at a higher rate of speed.
« Reply #18 on: May 25, 2009, 04:12:29 PM »
That's why all the Honda's have those big wings to create that down force over the driven tires so they get more bite, oh wait I forgot Honda's are front wheel drive those aren't wings they are clothes dryers, my bad.
« Reply #19 on: November 10, 2009, 03:04:53 AM »
Great explanation tazz.  The 2007 Pontiac Solstice GXP had the best Torque of the three with 260 lb-ft @2000 rpm, followed by the 2006 Nissan 350Z Roadster Touring with 260 lb-ft @ 4800 rpm, and then the 2006 BMW Z4 3.Osi @ 220 lb-ft @ 2750 rpm.  Can you imagine what the results would have been if the GXP had a Westers Tune back then?  Oh my, would that have been a wonderment and opened some eyes!
