Author Topic: New Coilovers for Solstice/Sky - Pedders  (Read 2368 times)
« on: May 27, 2009, 01:40:54 PM »
Pedders suspension stuff is all the rage for the late model GTO's my son told me he saw these for the Kappa's just figured I would post, they are expensive at $2399 but at least they are making more options available. They do springs for the Kappa too.
Solstice Xa eXtreme coilover
Pedders SportsRyder brand has been synonymous with high performance dampers for decades. Pedders SportsRyder shock absorbers and struts combine the most advanced technology with Pedders? renowned expertise in the fine tuning of damping rates for superior handling while maintianing close to OEM ride quality. At the forefront of sports suspension is Pedders eXtreme XA, height adjustable coilover built to Pedders stringent quality standards. Pedders eXtreme XA features sports calibrated tunable damping, motorsport coil springs individually tuned to suit each application and a host of other high performance features including engineered OEM compatible bracket. The eXtreme XA is the pinnacle of performance suspension technology. Height adjustment is achieved by turning the entire coilover into the lower clevis. The 2mm preload on the coil remains the same regardless of height. The range of travel remains the same regardless of the installed height. As the spring perch is not the source of height adjustment and the spring preload remains the same, ride quality is identical at minimum drop and maximum drop. The Pedders Sports Ryder eXtreme XA adjustable coilover range features 30 Position Adjustable Bound and Rebound Damping with a positive CLICK. These are positive Click-to-Tune positions. There is no guess work or doubt as to the setting. You can feel each click as you adjust the damping. How good is it --Driving with eXtreme Xa Coilovers is better than ___. DO NOT USE AIR GUN ON Xa COILOVERS. THIS WILL DAMAGE THE PART AND VOID THE WARRANTY
Retail      $2,399.00EA
https://secure.merlinsoftware.com.au/peddersusa/Default.aspx?ProdCode=160060
