Author Topic: New GXP/Z0K sway bar part number  (Read 203140 times)
Re: New GXP/Z0K sway bar part number
« Reply #75 on: July 05, 2009, 04:05:51 PM »
Bob you and U-238 have Sky's mine are Torx I looked again, it is possible they changed them at some point. T30 Torx fit perfect, we are going to Jmacs Sky I am hoping he has allen's.
« Reply #76 on: July 05, 2009, 05:49:33 PM »
Well, the T30 torx fit fine, but when I put some pressure on it I couldn't figure out why it wasn't biting. Got a mirror, took a look, and lo and behold it's an allen key.
Frankly, I'd rather have a torx than allen key.  :idk:
Oh, did some more "spirited" driving with the new sway bar. Before, on a certain 2-lane corner I'm familiar with, I'd start in the left lane, and end up drifing into the right lane when driving at speed. Now, the car will stay in it's lane, and you can feel the tires scrambling for grip. The new bar made a world of difference. Looking forward to the A/X meet on Saturday. Still haven't ever done A/X, so with a few fellow Kappa owners attending, now would be a perfect time to go.
« Reply #77 on: July 05, 2009, 09:15:49 PM »
Maybe it is an allen I do have new contacts and can barely see, they get adjusted tomorrow night maybe I will look again after I get new eyes. I am helping Jmac do his Tuesday night.
Offline Chemist
« Reply #78 on: July 06, 2009, 02:11:20 PM »
My 2006 Solstice has allens.
I'd rather be driving! :D
« Reply #79 on: July 06, 2009, 02:13:45 PM »
Chemist if you find someone with a GXP that gets the Z0K bar, the FE3 bar is the Z0K bar for the N/A, I passed mine down to Critter and Jmac is giving his to Smartin. So for about $20 in new bushings you get a an upgrade.
« Reply #80 on: July 06, 2009, 02:21:56 PM »
If anyone want my FE3 bar, let me know.
Offline Chemist
« Reply #81 on: July 06, 2009, 02:29:11 PM »
I'm running the GMPP system right now (got it for $650). It meets my needs (and exceeds those my wife thinks I need :D). I _will_ file the info away, however. :)
« Reply #82 on: July 06, 2009, 03:14:50 PM »
Is it with the bigger rear sway bar, should be 26 mm at least, 24 mm is stock.
Offline Chemist
« Reply #83 on: July 06, 2009, 05:28:26 PM »
Both bars are bigger than stock.
I'll try to crawl under the car and take a look "sometime soon." :D
« Reply #84 on: July 09, 2009, 01:04:54 PM »
Did you guys change the bushings at the end of the sway bar.
If you did what is the part number?.
« Reply #85 on: July 09, 2009, 02:27:58 PM »
Yes and the pictures of the bushings are posted, Jegs and Summit Racing both stock them, the rear are 26 mm for the stock bar 27 mm for the Z0K and 33mm for the front stock, just look them up under Energy suspension, by the size they are universal bushings, get the ones with the grease fittings.
« Reply #86 on: July 09, 2009, 02:35:16 PM »
They're available in red or black by the way.
« Reply #87 on: July 09, 2009, 02:44:36 PM »
Everyone knows red is faster
« Reply #88 on: July 09, 2009, 02:48:29 PM »
Wait, I though that was white?
« Reply #89 on: July 09, 2009, 04:31:18 PM »
LV, no bushings at the END of the sway bars, only links. The links are like two tie rod ends, but smaller, with a solid rod in between them.
« Reply #90 on: July 09, 2009, 06:28:17 PM »
Hey Bob if you were able to get replacement end links, adjustable or fixed? With urethane bushings of course, The guys from SS asked me. I told them there might be a market for both, I would not know how to adjust them, but I could learn.
Offline Deep-GXP
  • BooYah!
« Reply #91 on: July 09, 2009, 07:00:53 PM »
So im probably gonna order the Rear Sway bar.  I just want to make some things clear.
1 Rear Z0K Bar
2 27mm greased fitting bushings
2 33mm greased fitting bushing to replace the stock front bushings (this is worth swapping right??)
1 Tube of Synthetic Lube
Sound correct? How difficult is it to swap the front bushings?
Dealer quoted $130 for the bar, im looking on gmp direct and they have it for $125 shipped.  Might aswell go with the dealer if they tell me it's not back ordered.
Thanks guys!  I read the entire thread word for word but these are just some questions I'd like answered before I purchase everything.
:dancing::dancing::dancing:
« Reply #92 on: July 09, 2009, 07:25:56 PM »
you have it correct haven't done the front yet, so don't know but can't be very hard. Just get an 18mm ratcheting box end to do the back, and read Jmac instructions
« Reply #93 on: July 09, 2009, 07:34:57 PM »
snaponbob:
I already order the 27MM from Jegs.
However I was talking about the links, I thought they have grommets\bushing(s) on them.
I was following jonymac(spelling) thread of his install and went to the link he posted, there they recommend to also get the urethane bushings for the links.
Offline jonymac
« Reply #94 on: July 09, 2009, 07:41:18 PM »
Deep - you are right - I did grease my front bushings when they sarted squeaking this past winter - they aren't hard to get to or get off at all.  I eventually had the dealer replace them with the TSB bushings (nylon I think).
Latin - not aware of bushings needed for the links - at least I didn't see any when we were under the car.
Performance Mods
- Wester’s Race Tune
- Fujita CAI
- Dejon Intake TB Elbow
- Sprintbooster
- DDM Race Backbone & ProBeam
- Z0K Rear End
Other Mods
- Demoneyes
- Rain Sensing Wipers
- Flash2Pass
- Sound Deadener
« Reply #95 on: July 09, 2009, 08:41:42 PM »
snaponbob:
 There are no bushings for the end links yet, but I am working on it, Solstice Sport may make some for us, with adjustable end links.
« Reply #96 on: July 09, 2009, 08:59:14 PM »
Guys, there are NO bushings on our sway bar end links. There are NO bushings on our sway bar end links. There are NO bushings on our sway bar end links.
Lots of sway bar links DO have straight rods that are threaded at each end, and are secured to the sway bar ends and control arms with a sandwich of nut, washer, bushing, washer, sway bar end or control arm, washer, bushing, washer, and the unthreaded portion of the rod. THESE systems CAN use poly bushings. Ours have what looks like tie rod ends on each end of a rod. The tie rod ends go through the end of the sway bar and a part of the lower comtrol arms. Look at them - they are all the same. I still use the OEM end links on the GM sway bars, and on the custom big front bar there are adjustable emd links with Heim joints (ball ends). THEY ARE NOISY. The only reason I see for adjustable end links is to zero load then with the driver in the car. Not hard to do, and nearly useless unless you are the late Mark Donahue, or the top 1 percentile of race car drivers. BTW, with a bit of Google work, you can find them. There is just NO slop that will be eliminated with Heim jointed end links on our cars. None. Get the poly sway bar MOUNT bushings and YOU ARE DONE. That is, of course, unless you want to tell people you have adjustable end links.
« Reply #97 on: July 09, 2009, 09:02:13 PM »
BTW, I had stated earlier that a 6mm allen was neded for the end links. WRONG. They are FIVE mm allens. A T30 Tork WILL SEEM to work in there, but they will not stand any serious torque load and it is only a coincidence that a T30 "fits" in a 5mm allen .
« Reply #98 on: July 09, 2009, 09:19:56 PM »
So just to clarify do we need the end link bushings or not? :banghead: :poke:
« Reply #99 on: July 09, 2009, 09:30:30 PM »
Only lil goat does !!!!!!!!!!!!!!!!!!!!!!!!!   :D :D :lol: :lol: :rofl: :rofl: :goat: :goat: ;) ;)
