Author Topic: Need O2 sensor  (Read 2911 times)
Offline chuckdoc
Need O2 sensor
« on: June 07, 2009, 06:05:08 PM »
I keep throwing 2237 code, where is a good place to get a new sensor and what is the part number?
I reset the code and  it came back after about 300 miles.  I checked all the connections, both sensors are tight and the Solo CAT is tight also.  2237 is bank 1 02 sensor which I assume is the top sensor...
I found sensors at the following site but I don't know if it is a 2 or 3 wire sensor...
http://www.autopartswarehouse.com/search/?D=replacement+o2+sensor&Ntt=replacement+o2+sensor&Dx=mode+matchallpartial&Ntk=Main&Ntx=mode+matchallpartial&N=1697+4294963236+11543&Nty=1&V=1697&Vh=Pontiac&V=1697+4294963236&Vh=2007%20Pontiac
My KappaPerformance Mod Page
Re: Need O2 sensor
« Reply #1 on: June 07, 2009, 06:43:46 PM »
Just need to ask -
1) You say you have a Solo cat, so I assume it's their high flow cat. Yes?
2) If so, did you get the O2 sensor adapter that pulls the downstream sensor out of the exhaust flow? That is supposed to eliminate that problem.
3) Do you have a tune in your ECM? If so you can turn off that "alarm". There may be nothing wrong with the sensor.
Re: Need O2 sensor
« Reply #2 on: June 07, 2009, 07:13:52 PM »
He has the Solo CAT and the extension, the code is for the first 02 sensor, not the second.  Lyndon replied back that after resetting, if it comes back, change the sensor.   He is required to get an emissions check, does turning off the code report that to the emission when it is scanned?
Re: Need O2 sensor
« Reply #3 on: June 08, 2009, 10:15:16 AM »
If you turn it off it will report no reading, in VA. you are allowed to have I think 2 no readings and still pass. Not sure about MD. I am not sure about on the Solstice but my Harley uses the same O2 sensors and they can be cleaned (I use aerosol gun cleaner), there is also a procedure where you pull the sensor out into clean air and start the bike to reset the sensor, not sure if it will work on the car.
« Last Edit: June 08, 2009, 10:28:58 AM by lil goat »
Offline chuckdoc
Re: Need O2 sensor
« Reply #4 on: June 08, 2009, 11:19:54 AM »
Thanks, as to hi flow cat causing it, I have had that for over a year with 20,000 miles on it and no problems.  \
Really need to pass Md. inspection.  Cleaning might be a great idea however they are really cheap for a new one.  Around 40 bucks.  Real problem is whether it is a two wire or three wire.  Both are listed for 2007 GXP.
Re: Need O2 sensor
« Reply #5 on: June 08, 2009, 12:18:23 PM »
I don't know which 2 or 3 wire, the 3 wire are self heating, I don't see why they would need to be but maybe. I found this link and it says heated (so 3 wire) and $35. I think that may just be the connector but indicates 3 wire is what you need.
http://www.oehq.com/acdelco-parts_PT1069_ACD_ACDelco%20Heated%20Oxygen%20Sensor%20Connector~2007%20PONTIAC%20SOLSTICE%20GXP%202.0L.htm
 Rock Auto shows the complete sensor for $76.79
This seems like it is a little closer to waht it should be on the price.
http://info.rockauto.com/getimage/getimage.php?imagekey=501736&imageurl=http%3A//info.rockauto.com/Bosch/15280.jpg
