Author Topic: Modifing the gauge pod to move it closer  (Read 4923 times)
Offline dwdgraysol
« on: June 24, 2009, 03:29:46 PM »
These old eyes have a hard time seeing the fuel gauge in our cars.
It's to far down the tunnel for me to see it clearly during the daytime.
I was wondering if I could shorten the black tunnel and space the the gauges and
fmove all the gauges closer to the driver with longer bolts. is there enough lenght in
the wiring to allow this. :idk:
2008 n/a sly auto,
DDM Works stage II SC.
Re: Modifing the gauge pod to move it closer
« Reply #1 on: June 24, 2009, 04:08:09 PM »
I've had it apart several times, I think you can but there is a way to mod the guage to added brighter lights.  BlackCatCustoms.com.  I did mine and it's easier to see.
Offline DickW
« Reply #2 on: June 24, 2009, 04:38:29 PM »
DBG what did you get from BlackCatCustom? And how hard is it to install?
I drive with the foglights on and it is still hard to see th gauges>
« Reply #3 on: June 24, 2009, 05:22:57 PM »
There web site does not come up. Gone?
Offline LiquidPT
  • TechHead
    • LiquidPT's website
« Reply #4 on: June 24, 2009, 06:04:19 PM »
No, he just had an extra "s" in there:
http://blackcatcustom.com/
LiquidPT aka Matt
driving Black Sun
« Reply #5 on: June 24, 2009, 06:54:25 PM »
Thanks Liquid,
Tools needed:
Needle nose pliers
Soldering gun
Flux
Solder
1/4 universal
1/4 3" extension
1/4 drive rachet
7mm socket
Some soldering required.
Preparation.  Fill gas tank.  (don't laugh, it'll make sense later)
Pull out the chrome bezzel, tunnel and lift the surround, remove 4 bolts (7mm) that hold in the gage.
Pull back the gage and disconnect the single connector.  Remove and release the clear plastic through the clips, the same for the black support,
Now you have access to the gage face,  twist the needles to the left as you remove them (press on later), remove the gage face and you will see the little red lights, apply a solder gun to either side (top and bottom while holding with a needle nose) of each small square white box and remove them.  ::  the 4 dots to left represent what you will see after you remove both lights.  Install the new upgraded LED board with one wire going to the top left dot and the other to the bottom right.  I can't remember which is attached, you have a 50/50 shot.  After connecting the right one, go plug it back in and turn on the ignition (without starting).  See if it lights up.  If it does, then connect the left one the same way.  The top one is reversed for the wire colors.  Test it again to make sure all three work.  Press the boards down then reassemble the face plate and black portion.
Bring the 3 needles, go back and  plug it in and wait 20 seconds, turn on ignition (without starting and gage checks will be done).  Then install the needles by pressing the RPM and SPEED to ZERO and the FUEL to FULL
Turn off car and finish reassembly.
I did this so you would see how easy it is.
« Reply #6 on: June 24, 2009, 07:13:11 PM »
I also have a gauge from BCC, and I love it...I was the first one to order from them and they made their template from my gauge.  They were a pleasure to work with and I really recommend their products.
Offline 1KULSOL
« Reply #7 on: June 24, 2009, 09:01:33 PM »
I have this same problem and have been working with Dave/Randy @ DDMWorks .... hope to have something soon that will solve this problem ... and it doesn't involve brighter lights ..
Offline dwdgraysol
« Reply #8 on: June 24, 2009, 10:04:44 PM »
Thats great. Keep me in mind when they come up with thw answer.
2008 n/a sly auto,
« Reply #9 on: June 25, 2009, 07:17:36 AM »
Didn't JPM do an entire gauge upgrade? If I remember right it was SWEEEEET! I think they did it while they weren't doing my door handles.
« Reply #10 on: June 25, 2009, 07:23:51 AM »
Hey Goat, When you going to get your door handles done?   I think it would look great, you should get off the fence and get them done.
« Reply #11 on: June 25, 2009, 07:51:28 AM »
Door handles, door handles, I don't need no stinkin' door handles, door handles are for siissy's or at least that's what JPM told me. I spoke with Mr. JPM my door handles were at NASSM on vacation, someone who shall remain nameless, thought I would be there and was nice enough to bring them for me, unfortunately I was not there. Now where is that gauge pod picture, hmmmm
« Reply #12 on: June 25, 2009, 08:13:44 AM »
JPM did the gauge cluster in that car with the V8 conversion.  It was really nice looking.  i want to say that they used Autometer gauges if i am not mistaken.  It looked so nice!!!
