Author Topic: Artic Chill A/C Filler  (Read 3264 times)
DarkSlySol
« on: July 12, 2009, 11:44:50 PM »
Has anyone used that R-134a Synthetic A/C Booster yet? Its supposed to help ease the strain and improve MPG and I believe its supposed to be 20% cooler. The A/C blows out cool air but I want that artic blast to come out hahah
Re: Artic Chill A/C Filler
« Reply #1 on: July 14, 2009, 08:00:25 AM »
Do you mean this
Super Chill™ was developed as an A/C system performance enhancer.
• Boosts A/C performance
• Lowers vent temperatures & improves system efficiency
• Containes Stop Leak to rejuvenate o-rings and seals
• Reduces friction in compressor
• Compatible with all 134a mobile systems
• Comes in a easy to use aerosol can attached with pre-vacuumed hose to avoid air entry into system during initial connection.
I had never heard of it, who's going to be a guinea pig?
« Reply #2 on: July 14, 2009, 09:14:36 AM »
Not me, my A/C works fine now - when I use it.  I usually have it set on a fan speed of 1, because I don't carry a sweater.
« Last Edit: July 14, 2009, 02:02:10 PM by Critterman »
DarkSlySol
« Reply #3 on: July 14, 2009, 02:00:08 PM »
Its acutally the Sub-Zero brand......If its the same type of freon what's the problem with changing it?
« Last Edit: July 14, 2009, 02:06:49 PM by DarkSlySol »
Offline GaryH
« Reply #4 on: July 22, 2009, 10:42:00 AM »
If it contains "stop leak" I stay away from it.  If it will stop a leak, it will stop up other stuff, like expansion valves, driers, evaporator and condenser coils.
07 Sky
VIN  1745
Magnaflow Quad Tip exhaust
Tail of the Dragon 2008
Denver 2009
Ohio 2010
08 Sky DDM SC stage ll
Solo Mach exhaust
