First of all, I really appreciate you guys taking your time to read my post
Ok so maybe about 7 days ago:
I noticed my car running a little rougher than usual. The car felt like it started to idle a little rougher. I was in Filipps car when he had a bent valve and it's NO WHERE near that shakey...but it does feel a bit rougher. When I go WOT, it boost fine at first but then it feels like it loses boost/power for a while then some times it'll pick back up if i stay on it but most of the time I just let go of the gas pedal. Sometimes I hear loud pops which i guess are coming from the cat.
About 6 days ago:
It seems like my exhaust tone changed, especially at idle. A bit louder and it definitely rumbles the car more. Coolant Temperatures seem to be staying at 200 or more when normally my temperatures are under 200. I even saw it at 210 for a while and as high as 216.
About 4 days ago:
I went WOT, then the power kinda cut out like I previously explained and I threw a code which ended up being a cylinder 3 misfire. It did NOT go into limp mode, but the power definitely reduced a bit until i saw the check engine light FLASHING for about 5 seconds then disappeared.
About 3 days ago:
I was filling up with my usual gas and when I went to start up my car it was a NO GO. On my 2nd attempt, the car cranked longer than usual but it fired up.
About 2 days ago:
My car didnt start up on first attempt again but started up just fine on the 2nd attempt.
Yesterday:
I went out for ice cream and parked in the same underground parking lot that I ALWAYS park in. When we get our ice cream we usually go back to the car and eat it inside with the A/C on (i know i know, ice cream in the sol...sorry
) But anyway, this time I could definitely notice the difference in the exhaust sound. There was no way I could have my car on inside that parking structure because it was TOO freaken loud. I think i finally experienced drone for the first time. It was hurting our ears and it was impossible to hold a conversation. I have always parked in this parking structure with the car on and never had a problem with relaxin there for 10-15 min.
What do you guys think?
What I plan to do for now....
Wash my air filter
Clean the MAF Sensor with MAF sensor cleaner
Check exhaust for leak
Check all my T-Bolts cuz I actually noticed that one of my IC pipes is sliding off.
Take logs and send them to Lyndon
