Author Topic: Saddle Squeak - new fix  (Read 20003 times)
Re: Saddle Squeak - new fix
« Reply #25 on: July 21, 2011, 04:22:45 PM »
Ahhh, thanks Bob.  I think I was confused by another post somewhere that associated the buttress pins with the squeak (probably mistakenly).
« Reply #26 on: July 21, 2011, 04:51:24 PM »
Yeah this squeak only occurs while the top is down.
« Reply #27 on: July 21, 2011, 09:28:28 PM »
Adhesive backed velcro should work. Hook or loop, your choice.
« Reply #28 on: July 21, 2011, 10:49:41 PM »
A friend said that he can get me a Kevlar glove that I can cut a piece off of and glue in there. Assuming I can cut it, that sucker will NEVER wear out.
Thinkin' I can cut it with a cutting tip for a soldering gun 'cause I don't think a knife will cut that stuff.
Should have it tomorrow. Maybe it'll be a little cooler here by then...
« Reply #29 on: July 21, 2011, 11:57:42 PM »
I sharp knife should cut it just fine.  Kevlar is better at stopping bullets than knives due to its low stretch, high tinsel strength qualities.  Walk up to the next cop you see, shoot him and stab him and see which one does more damage! LOL!!!!!
« Reply #30 on: July 22, 2011, 08:34:34 AM »
[...] high tinsel strength qualities.
...and good for decorating Christmas trees too!  :lol:
« Reply #31 on: July 22, 2011, 08:54:58 PM »
You should be able to cut it with a good pair of scissors.  I have also used wire cutters with good success on Kevlar.
« Reply #32 on: July 23, 2011, 12:03:38 PM »
You guys were right. I had tried to cut the Kevlar glove with a cheap pair of scissors and that didn't go well at all. A good pair was what was needed. The problem with the Kevlar though is that is frays like crazy and if it cuts that easily is no better solution than the leather was.
Leathers have been used on motorcycles for years because of it's abrasion resistance to protect the rider from road rash. The finger tip from a heavy leather glove fit it like a glove. (pun intended :D)
Here's a pic to show the post in question. The top has to be down to access it. If you have a squeak behind you, check it out. I thought for the longest time that the squeak was coming from the large plastic panel from behind the seats.
« Last Edit: July 23, 2011, 12:06:46 PM by Sly Bob »
« Reply #33 on: August 02, 2011, 09:41:15 PM »
I had the top down on my car the other day, and noticed on mine that these saddles already have felt covers on them. Another improvement found on the '09 cars?
« Reply #34 on: August 02, 2011, 10:58:55 PM »
No, the felt wears through and then you get the noise.  My very low mile 07 has the felt and it is almost wore through last I looked.
« Reply #35 on: August 02, 2011, 11:17:46 PM »
Ah ok. The felt did look to be in pretty rough shape but I haven't noticed any squeaking. But then, with stiffer springs there are so many rattles and squeaks I'd go crazy trying to pin them all down.
« Reply #36 on: August 03, 2011, 07:35:25 AM »
Do the glove thing or grab an old rag of some sort and stick it under the pin in the trunk to see if some of your squeaks go away. I can drive over railway tracks and there are no squeaks at all. If the felt's a little rough that's likely what at least one of the issues is.
« Reply #37 on: August 03, 2011, 01:07:46 PM »
I thought I had this issue. However, I chopped off a pinky from some old gardening gloves and installed it at lunch time. It didn't work. My search for the annoying squeek continues...
« Reply #38 on: August 03, 2011, 01:18:15 PM »
I know I asked before but where is Reed?  Your not driving his car and backing into things are you?  GJ installed something in Reed's car that would do that you know?
« Reply #39 on: August 03, 2011, 01:24:57 PM »
Reed is at work. This is a picture I received from him a few minutes ago. I guess he thinks it's still July 4th or something?[attachment=1]
No I'm not driving his car and I'm definitely not backing into things. Just driving my own car around with an annoying squeek. I even made Morfious drive it the other day so he could listen. He thought it could be this problem as the felt is torn on mine. Alas, it was not the issue.
« Reply #40 on: August 04, 2011, 12:56:21 PM »
Are you calling Morf an annoying Squeak?
« Reply #41 on: August 04, 2011, 01:08:38 PM »
:lol: Nope, if anyone is the annoying squeak it's me.
For now I just turn the radio louder so I don't hear it. My neighbors love that!
