Author Topic: New RDC exhaust backfire?  (Read 3358 times)
Offline DragonSolGXP
« on: August 14, 2009, 09:46:03 AM »
Hi Jeff,
Loving the RDC solo exhaust, but I'm experiencing some backfiring.
Here's the problem as described to someone else:
...took her out today and gave her a good run. She's still pretty wicked. VERY fast off the line. I noticed one thing however. When going fast off the line and switching from 3rd to 4th, when just about at 6000 rpm when I let off on the gas to switch gears it back fires. Is this normal?
I was told it was an exhaust leak?
Does anyone else experience this?
Is it Normal?
Jeff, if it's not normal can I drop by the toronto garage and get it checked out?
Thanks
Re: New RDC exhaust backfire?
« Reply #1 on: August 14, 2009, 12:32:09 PM »
Do you have the high flow cat?  Westers can update your tune to help change the backfiring
« Reply #2 on: August 14, 2009, 01:54:08 PM »
No, just the stock cat. I was thinking of getting the high flow cat as well, but I didn't want to increase any problems.
« Reply #3 on: August 14, 2009, 02:49:30 PM »
I have had the problem, easy fix usually, just adjust the band clamps. most likely one of them shifted a little after install, or is not quite tight enough, it just takes a tiny little pin hole to cause this problem, it can also be caused by the gasket at the turbo to the CAT, that is a GM issue, I had 3 of those gaskets fail, since you have the stock CAT, that would be the first place I would look.
« Reply #4 on: August 14, 2009, 03:30:13 PM »
Thanks Goat, I'll look into that this weekend.
