Author Topic: DIY Engine & Fuse Box Cover  (Read 5435 times)
Offline Charlie W
« on: August 22, 2009, 05:31:43 PM »
I received my first Social Security check this month, and I'm on a much tighter budget. To save money I try to make the things I want for the car.
Two weeks ago I purchased a 12 X 32 X 1/4 piece of T-6 aluminum for $35.00. I used my old tunnel brace as a template to lay it out and drill the holes on my drill press and cut to size on my metal cutting bandsaw.
This week I purchased a 18 X 24 X 22 guage piece of mirorr polish stainless steel for $55.00, a 6mm X 1.0 X 1M threaded rod for $6.00 and 4 stainless steel acorn nuts and flat washers for $8.00. I made a new engine cover about the same size as old one and uses the same holes. And I had enough left over for a fuse box cover.
Aggressive,5-speed Manual. Mods: Westers Race Tune, K&N Drop In Filter, Dejon SS BOV Spring, JPM Visor Covers, 3M Clear Bra, GM Splash Guards, Shorty Antenna, Silver Painted Calipers W/Red GXP Letters, Red Arrow Decals, JPM Stitched Console, Silver Painted Rotors, Mirror Polished Stainless Engine Cover, Fuse Box Cover and Visor Mirrors, DIY Tunnel Brace, Dual Horns, DDM Pro-Beam.
Re: DIY Engine & Fuse Box Cover
« Reply #1 on: August 22, 2009, 06:45:11 PM »
You should take pictures during the day.
Looks clean and shiny, reminds me of the impeccable rebuilt hot rods' engines.
Thanks for sharing.
« Reply #2 on: August 22, 2009, 08:50:00 PM »
Looks amazing
Good Job!!
Offline BLK GXP
  • Rollin'
« Reply #3 on: August 23, 2009, 12:09:58 AM »
sweet
Offline Charlie W
« Reply #4 on: August 23, 2009, 01:47:24 PM »
Thanks for sharing.
As you requested here are a couple of pictures taken out side. The others were taken in my garage.
Offline nolanb
« Reply #5 on: August 23, 2009, 08:53:49 PM »
Amazing.  You did a great job!
« Reply #6 on: August 23, 2009, 09:53:58 PM »
You obviously have access to some metal working tools. To cut that so cleanly and then bend it in a break takes some talent. Nice Job!
Offline Charlie W
« Reply #7 on: August 24, 2009, 05:08:16 PM »
I have a drill press and bandsaw, but I don't have a brake. I C-Clamped the material under an aluminum straight edge to a piece of 3/4 inch plywood. Then I took two pieces of wood baseboard molding, with a tapered edge, cut a little longer than the part. I screwed them together to keep them lined up and loosened the screws to slip over the part. Then I used heavy duty c-clamps to hold them tight. I used a 18 inch adjustable wrench on the wood to make the bend. I also used a electrician's knock out punch to make the radiused cutout for the oil filler, then bandsawed to the holes and in between and a disc grinder with a flapper wheel to finish the edge.
__________________
Offline yellowsky
« Reply #8 on: August 25, 2009, 12:31:41 AM »
wanna make another?
Offline Charlie W
« Reply #9 on: August 25, 2009, 09:15:49 PM »
wanna make another?
This link is for Dejon Powerhouse a supporting vendor on this Forum
http://solstice.dejonpowerhouse.com/
Under appearance items he has a similer engine cover that some might consider better than my design. He includes all the hardware to mount it. He also has a fues box cover.
Buy the time I had the material shipped to me, purchased all the hardware, and shipped to you I would have to charge you as much as Dejon. Go to his web site and check it out.
