Well, on Friday at 91870 +/- miles the battery on PoPs car decided to die. Use to a battery would give you some warning but nowadays they just goes poof. Took Mrs. PoPs her cell phone which she had left at home and when I got back in the car it went click and nuttin'. Managed to jump it off and drive it home. Got out this am and tackled the change out. Went pretty well for a non-gear head. Only one bolt offers a challenge but it wasn't that bad.
Here's the starting point. There are seven black screws size 7mm. Three on the top of the fender and four on the wheel well.
In addition there are three 10mm screws. Two underneath and the challenging one behind the door.
I'm not a gearhead so don't have all the fancy schmancy tools so I took a piece of Scotch tape and made a loop and stuck it to the end of a 10mm socket on a six inch 3/8 extension. Seated the socket over the bolt head and removed. Worked well on removal and installation.
Once the fender skirt is off you need to remove the bracket. The holes on the bracket are oversized so I marked the location prior to taking it off. If'n you don't the bracket will slide out of it's originial position and it could mean some additional line up time later. The bracket is held in place with two 10mm screws and a 10mm washer nut on the front brace.
With the bracket out of the way all you need is a 10mm socket to loosen the battery terminals and a 13 mm socket to take the hold down bracket off.
This is what you're working towards.
New battery installed.
One thing to watch out for is on the install. Make sure the majority of the wheel liner is in front of the fender. There is a notch in the fender well liner.
Said and done.
Overall took 1 1/2 hrs and that included the trip to O'Riellys to get a new battery. If'n I can do it then it should be a piece of cake fer all y'all professionals.
