I installed the front bushings, first off they shipped the wrong ones, no grease fitting, what do I want for $12 I guess. I installed them anyway, REALLY easy, drive up on ramps, take out 2 15mm bolts each side install. the ones that were on there are the ones from the tech bulletin THEY ARE HUGE. I would guess at least 3/4" thick all the way around maybe more. The replacements are maybe a 1/4" they actually move the position of the bar up a bit. I went for a test run. Hit some extreme speeds and the car feels less vague, handling is a bit more precise and it would seem less understeer, I like it. I am not sure how they would be with other suspension setups but with all the DDM goodies and the HKS coilovers seem to work well. I have the damping pretty high on the shocks. I did notice the bushing seemed to be a bit small, it fit but there was a small gap when everything was tightened down. I wonder if the front bar may not be 34mm instead of 33mm. I may blow another $17 and get the bigger set with the grease fittings, the new ones are no more than 1/3 the size of the stock ones. Bob said he didn't like them with the Z0K bar, I like them with the stock bar, certainly worth the money in my book. I am sure I want them to feel better and am a bit prejudice, I can honestly say you will feel a difference. If it is good or bad, that is for each to decide, sure is easy and inexpensive.
