Author Topic: Mounting of Dashhawk  (Read 3470 times)
Offline Bailey
« on: October 03, 2009, 06:31:25 AM »
After purchasing the Dashhawk...good decision...I have been pondering where might be the best mounting location?  Has anyone nounted their with the bracket provided...and where did you located it?
Bailey
'06 Solstice NA
GGMP CAI,
Solo Performance Header, Hi-flow Cat, 2 1/2 N/A Single Exhaust
Vector Motorsports Tune
DDM Works Back bone & Pro-beam
Eibach Pro Kit Springs
MRZ Performance Polished Billet Covers (various)
Re: Mounting of Dashhawk
« Reply #1 on: October 03, 2009, 07:37:49 AM »
I have mine installed in the speedometer area and then I have digital speed listed as one of the 4 display squares.  I pulled the tunnel and nipped a slot in the bottom left side and ran the cable through there to the OBD II.  It's hidden and then I added a small piece of stick on foam on either side of the dash hawk so it is held firmly in place.
« Reply #2 on: October 03, 2009, 07:40:56 AM »
here is an old pic but the cable isn't visible anymore.
Offline Chemist
« Reply #3 on: October 03, 2009, 08:22:59 AM »
I have mine in the lower left corner of my windshield, cable routed through the dash panel covered by the driver's door. I'll get some pics later today. Headed out right now for the Race for the Cure.
I'd rather be driving! :D
Offline perris
« Reply #4 on: October 03, 2009, 12:14:08 PM »
that's where I had mine too, I also routed the wires inside the dash by the door, didn't have to remove anything to do that either
I personally used one of those plastic sticky pads to just rest it between the pillar and the dash, not reall secure but simple
Offline rich71
« Reply #5 on: October 04, 2009, 07:44:03 AM »
i have mine mounted on the steering colum in front of the speedo pod using the bracket and the "velcro" that comes with the kit. I can't see the speedo from 0-20mph, but that doesn't concern me. i display iat, oil temp, coolant temp, afr, knock retard and volts. and the dic i have set on boost
2007 Midnight Blue Redline
Manual Trans
Westers Race Tune
Hahn Intercooler
GMPP Catback Exhaust
ReBar
DDM Race Backbone Brace
JPM Shifter
Sprint Booster
K&N Filter
Stubby Antenna
BMW LiftPucks 4the BLIND
« Reply #6 on: October 04, 2009, 08:35:36 AM »
Steering pod
Offline perris
« Reply #7 on: October 04, 2009, 09:14:23 AM »
you guys do know the dash is differant for a sky then a solstice right?
he has a solstice
