Author Topic: how does our parking brake adjust?  (Read 3291 times)
Offline perris
« on: October 09, 2009, 02:11:50 PM »
so I have the car about 45000 miles and wondered why the parking brake never seemed to self adjust but no worries for me it was still effective, just more travel then when I got the car
then bing, all of a sudden it adjusted and it is back down to factory travel, any idea what's going on here?
how does our parking brake adjust when you have manual transmission, is it done in reverse?...do I need to pull the brake at any specific time while doeing something else?
thanx for the info in advance
« Last Edit: October 15, 2009, 08:43:51 AM by DeepBlueGXP »
Re: how does our paring brake adjust?
« Reply #1 on: October 09, 2009, 03:26:18 PM »
I believe there is a ratchet in the e-brake mechanism at the calipers. Apparently there was enough travel to advance a tooth in the ratchet.
Offline perris
« Reply #2 on: October 09, 2009, 03:51:23 PM »
makes sense snapon robert!
thanx for the info
Re: how does our parking brake adjust?
« Reply #3 on: October 15, 2009, 08:47:54 AM »
Pull off the center console, at the end of the brake cable, tighten the bolt facing aft. You need a deepwell 10mm or a 10mm rachet wrench.
To remove the center console, pull the parking brake up then lift from the back section (just in front of the rear cupholders) and once released, slide afte and lift over the parking brake.   Then lower the parking brake handle and tighten the bolt
« Reply #4 on: October 15, 2009, 08:50:39 AM »
The brakes are self adjusting, the option Joe offers in to tighten the cable.
« Reply #5 on: October 15, 2009, 09:16:32 AM »
Critter, correct but Deep's talking about the OTHER adjustment. The cable can/does stretch. For some reason my calipers don't seem to adjust correctly or the cable has a problem and I actually had to install a few washers at the handle end of the cable to take up enough slack to be able to adjust it properly. Works fine now.
Offline AdamVIP
« Reply #6 on: October 15, 2009, 09:02:59 PM »
Somewhere on the BB theres a tutorial on how to adjust it.
When my parking brake went it was actually a problem with the rear caliper neeing to be recompressed.   I got it done under warranty but its something to look at.
2007 Manual GXP
her name is Victoria (Tori with the top down)
Offline seal9
« Reply #7 on: October 17, 2009, 09:49:53 AM »
To adjust the back rachet you hold the p/brake button in and jack it up and down quickly and that should do it took me hour to find out how. seal9
Chili Pepper Red Loaded/LSD
White Redline Stock
Long tubes/Free Flow Cat
Thermal Research Dual Exhaust
DDM Supercharger Stage II.5
DDM Shock Tower Brace
KONI Adj Shocks
DDM Brakes/Pro Beam/Back Bone
Wideband AFR /Boost
Water/Methyl alc Inj
Offline perris
« Reply #8 on: October 17, 2009, 10:01:22 AM »
that explains it for me, I went to a parking lot and tried some drifting, bing, adjusted parking brake
