« Reply #17 on: March 04, 2010, 02:53:09 AM »
IN my research on building a race lnf engine I was amazed that Gm racing quit offering the 2.4liter racing block @ a cost of $5,300. Found out their block was cracking at oil intake port right front side. Ray Bates engineering has designed and builds a block that can handle up to 1,400hp with no cracking problems. This block failed because the sleeve failed 1st. The engine should be resleeved once it hits the 400hp + stage. Finding a good sleeve is a problem. Darton offers a set of 4 sleeves for around $650.00 but you must have Darton install them.Complicated I took these to four machine shops that do race engines and everyone said they don't have proper equipment so I returned them. Bates engineering installed his race sleeves/size classified foraround $2,000 on my engine.Ray Bates is a specialist in Ecotec Race engines and has helped develop engines with GM racing. Note Bigger sleeves would require custom 2.4 liter gasket from cometic 83mmpistons wiseco Max .lNF can go
Logged
