Author Topic: What did you do to your Kappa today!  (Read 1539334 times)
0 Members and 5 Guests are viewing this topic.
« Reply #4650 on: July 12, 2011, 01:20:25 PM »
hope you solve it soon Aspenrose..this elff has already taken too much of your time and patience!
I agree, beware of the Elff! Elves are always causing problems!
« Reply #4651 on: July 12, 2011, 01:47:56 PM »
HEY!!!!!
o wait, nevermind...  Guilty as charged
« Reply #4652 on: July 12, 2011, 02:03:24 PM »
I finally installed dual oil catch cans. I needed to build a mount for the cans and I kept the check value in place. I ran some clear hose from the drains on the bottom to down behind the front bumper for easier draining. I'll let everyone know how much oil I get in both cans.
Assuming that you've kept the two piping end points the same and just inserted the OCCs inline (difficult to see from the photo) and since you've kept the check valve there, you should never get any oil in that left can unless the check valve fails.  With the check valve in place, it's an an engine air-intake only.
You should never get oil in the second one either, since there's a baffle set in the valve cover that (should) act as an oil catch can itself.
Be interesting to see what actually happens though.  I've been struggling about the need for an OCC myself and pretty much decided just to put a clear fuel filter in line with the check valve.  If that shows oil, then I (in theory) know that the valve has failed and can replace it.
One question, what did you use to connect into the push-on fitting on the end of the factory pipe?
Offline Dr. Gronk
  • carpe diem incoronatus
« Reply #4653 on: July 12, 2011, 02:32:41 PM »
Yes I put the occ's inline, the rear crankcase connection runs to an occ and to the intake just after the maf. The front crankcase connection runs to an occ and to the intake right at the turbo.  Here's the pic again (as it's on the previous page).
I agree, I hope there is never any oil in the the left can (or the right for that matter) due to the one way check valve. I suspect the engine oil may have been overfilled or the check-valve failed in the past though as I found oil residue near this port inside the intake pipe.  I installed the 2 can's more of an experiment and thought I could share the findings here.
For the push on fittings I called a few parts stores to ask about 3/8" gas lines with quick disconnect ends, and ended up buying a Double Bead Line 12" x 3/8" from napa (part num is 730-4931). As I only needed on quick connector on each side I cut the line to length with a small pipe cutter (for copper pipe etc) and used one side to connect to each of the stock lines.
« Reply #4654 on: July 12, 2011, 02:57:14 PM »
Excellent and helpful info.  Thanks!
Offline Houstice
« Reply #4655 on: July 12, 2011, 05:59:48 PM »
Ordered and paid for for DDM's Stg. II Supercharger setup with powdercoated valve cover and coil cover. To be installed mid August. :yay: :yay: :yay:
Offline sallysky
« Reply #4656 on: July 12, 2011, 07:40:31 PM »
My DDM powder coated charger tubes and valve and coil cover shipped today woo hoo I should have them Firday! I will attach pics when they arrive. Too bad I can't do the work myself this weekend.
2008 RL Bluestone/Tan/Black Leather "Sally"
"SKY4JOY"
5 Speed
Vision Wheels
Stubby
Custom Etched Glass Windscreen
Kenwood DNN991HD
Alpine PDX-v9 Amp Infinity Kappa Front & Tweets Kicker Rears and sub
Brake Light Decal
Painted Calipers
Silver Marker Bulbs
RPI GT exhaust
GMPP CAI & Turbo upgrade
Color Matched Badges
DDM backbone & venom brace, Pro Beam
JPM Dash, console, trunk liner, shifter
Norms rear facia, side skirts, front splitter
Custom Painted Hood Liner
Blue powder coated pipes
VDI Hinges - Halo- HID
Offline krelubot
« Reply #4657 on: July 12, 2011, 07:50:13 PM »
Put on new tag... "BOT"
Offline EarthNTX
« Reply #4658 on: July 12, 2011, 08:27:05 PM »
Sat in the garage staring at it.  :drool:
Ride it like you mean it.
« Reply #4659 on: July 13, 2011, 02:27:41 AM »
:lol: :lol: :thumbs:
  :ttiwwp:
Offline IBDRINKEN
  • Donkey Master
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #4661 on: July 13, 2011, 03:33:51 AM »
IBDRINKEN, i don't get the horse-donkey icon... sorry.. it must be a language barrier
can you explain what it means?
Offline Aspenrose
« Reply #4662 on: July 13, 2011, 04:43:35 PM »
 installed the JPM loops, black w/red stitching  :thumbs:
thought about installing the hide-a-way front plate, still thinkin' on it. Hard to swallow any plate on the front, but tired of being harassed by the MN, IL, and lately WI cops.
« Reply #4663 on: July 13, 2011, 06:21:41 PM »
« Reply #4664 on: July 13, 2011, 06:40:54 PM »
B.S. or jack@$$
take your pick
Elff I know this makes sense to you but I didn't understand that one when I moved here either.
Arabas... to translate Elff's American into English to be translated into Greek. In American a jackass (donkey) is used to refer to someone that is acting stupid.  So next time Kelu says something you don't agree with, no need to argue, just put :donkey: it speaks volumes.
« Reply #4665 on: July 13, 2011, 06:47:38 PM »
I keep forgetting about the translation.
These guys type better english than people who live in the USA so I forget that they might not get our slang or jokes.
 :thumbs:
Offline duckSol
  • Onward through the fog
« Reply #4666 on: July 13, 2011, 10:25:01 PM »
 :huh: Y'all got sit bass ackwards   :idk:
Jousters don't ride jack ass's, they ride horses   :nuts:
« Reply #4667 on: July 13, 2011, 11:17:59 PM »
:donkey:
« Reply #4668 on: July 13, 2011, 11:41:54 PM »
 :lol:  :rofl:  :thumbs:
« Reply #4669 on: July 14, 2011, 06:21:29 AM »
And that Arabas is the proper way to use the emoticon.
« Reply #4670 on: July 14, 2011, 10:39:28 AM »
This thread is locked in efforts to speed up the forum.  Continue here -> http://www.kappaperformance.com/forum/index.php/topic,7532
